JIDE OSS 2.4.3 with Java 5
Postby arminhaaf » Tue Oct 21, 2008 1:44 pm
What is the target java version for JIDE OSS ?
the artefact deployed on the jave.net maven repository is compiled for java 6. Is this just by mistake or a must?
arminhaaf
Re: JIDE OSS 2.4.3 with Java 5
Postby JIDE Support » Tue Oct 21, 2008 1:48 pm
We compiled using JDK6 but with the target set to 1.5. You should be able to use it in JDK5.
Postby arminhaaf » Wed Oct 22, 2008 2:15 am
sorry, but it is not possible to use it with java 5
bad class file: /home/user/.m2/repository/com/jidesoft/jide-oss/2.4.3/jide-oss-2.4.3.jar(com/jidesoft/swing/JidePopupMenu.class)
class file has wrong version 50.0, should be 49.0
arminhaaf
Postby JIDE Support » Wed Oct 22, 2008 11:44 am
Please update the jar. I just fixed it. It was broken since 2.4.2 so I fixed both 2.4.2 and 2.4.3.
Postby arminhaaf » Wed Oct 22, 2008 2:50 pm
thanx it works now,
there just one minor issue, on maven builds we get some warnings
[WARNING] POM for 'com.jidesoft:jide-oss:pom:2.4.3:compile' is invalid. It will be ignored for artifact resolution. Reason: Failed to validate POM for project com.jidesoft:jide-oss at Artifact [com.jidesoft:jide-oss:pom:2.4.3:compile]
arminhaaf
Postby JIDE Support » Wed Oct 22, 2008 3:12 pm
Hmm, is it the first time you see this?
Postby arminhaaf » Thu Oct 23, 2008 1:04 am
while we used 2.2.2 we didn't get that warning
debug info:
Validation Errors:
[DEBUG] For dependency Dependency {groupId=aqua, artifactId=aqua, version=5.0, type=jar}: system-scoped dependency must specify an absolute path systemPath.
arminhaaf
Postby JIDE Support » Sat Nov 01, 2008 1:11 pm
Just so you know this is fixed in 2.4.4 release.
Postby arminhaaf » Fri Jan 30, 2009 1:36 pm
The same problem (not usable with java 5) is introduced again in 2.4.7 and still there in 2.5.0
arminhaaf
Postby JIDE Support » Fri Jan 30, 2009 1:48 pm
I am sorry but which problem? This thread mentioned two problems.
Postby arminhaaf » Mon Feb 02, 2009 1:26 am
sorry, i meant it is not usable with java 5 since 2.4.7
arminhaaf
Postby JIDE Support » Mon Feb 02, 2009 8:09 pm
Just so you know, this is fixed in 2.5.1 release. We finally figured out what causing the problem so it will never happen again.
Postby arminhaaf » Thu Feb 05, 2009 2:14 pm
sorry, but it is not fixed, at least not in the version in the maven repo:
bad class file: C:\Documents and Settings\Administrator\.m2\repository\com\jides
oft\jide-oss\2.5.1\jide-oss-2.5.1.jar(com/jidesoft/swing/JideButton.class)
arminhaaf
Postby JIDE Support » Thu Feb 05, 2009 2:21 pm
My bad. Sorry about this. I will make sure it is fixed in the next release.
Postby JIDE Support » Sat Feb 07, 2009 7:39 pm
Just so you know, this is fixed in 2.5.2.
