Please add JIDE version to the evaluation pop-up dialog
Postby ForceRs » Mon Jun 14, 2010 8:53 am
This enhancement request is to simply show the JIDE version int he evaluation pop-up dialog that appears when initially running JIDE.
It would be handy for developers to be ale to report the version they are running to you if/when potential issue arise during the evaluation period.
I see "Jide-Version: 2.9.3" in the jide-grids.jar, so the information appears to be available.
ForceRs
Re: Please add JIDE version to the evaluation pop-up dialog
Postby JIDE Support » Mon Jun 14, 2010 10:00 am
If you are running JIDE JideDemo, you would find the current JIDE version number on the title of the main window. We don't want to duplicate the information if that helps.
Postby ForceRs » Tue Jun 15, 2010 6:12 am
Okay. I will open the .\jideDemo\Readme.txt file from the extracted evaluation package file structure to determine which version I am running in my own test code.
ForceRs
Postby JIDE Support » Tue Jun 15, 2010 9:09 am
OK. Will put the release information somewhere in the dialog in 2.9.4.
