IDE Designer
IDE Designer
Postby HenryMiller » Thu Jun 10, 2010 5:42 am
Good afternoon,
I would like to know if there is a Java Swing Ide Designer class within your products.
Something similar to IDE Netbeans .
At the moment my panels are built at run time retrieving field , rows,columns from an xml file.
Giovanni
HenryMiller
Re: IDE Designer
Postby JIDE Support » Thu Jun 10, 2010 7:30 am
We don't have a GUI designer inside JIDE but you may give JFormDesigner or Window Builder a try. They provide support for JIDE components.
Re: IDE Designer
Postby HenryMiller » Thu Jun 10, 2010 7:55 am
I'm going to test JformDesigner.
Best Regards
Giovanni
HenryMiller
Re: IDE Designer
Postby HenryMiller » Thu Aug 25, 2011 3:08 am
Hi Paul,
I've just used the help provided with JformDesigner.
hth
Giovanni
HenryMiller
