Gradient fill in JideSwingUtilities
Postby Skjalg » Fri Jan 15, 2010 3:15 am
I suggest adding these three methods to JideSwingUtilities, for easier use:
This method is just a help method so you can specify a component instead of a rectangle
    public static void fillGradient(Graphics2D graphics, Component component, Color startColor, Color endColor, boolean isVertical) {
        Rectangle rectangle = new Rectangle(0, 0, component.getWidth(), component.getHeight());
        JideSwingUtilities.fillGradient(graphics, rectangle, startColor, endColor, isVertical);
This method paints two gradients, with 3 specified colors so you can achieve a bar or pipe look.
    public static void fillGradient(Graphics2D graphics, Rectangle rectangle, Color startColor, Color middleColor, Color endColor, boolean isVertical) {
        Rectangle top = new Rectangle();
        if (isVertical) {
            top.setRect(0, 0, rectangle.getWidth(), rectangle.getHeight() / 2);
            top.setRect(0, 0, rectangle.getWidth() / 2.0, rectangle.getHeight());
        Rectangle bottom = new Rectangle();
        if (isVertical) {
            bottom.setRect(0, (rectangle.getHeight() / 2), rectangle.getWidth(), (rectangle.getHeight() / 2));
            bottom.setRect((rectangle.getWidth() / 2), 0, (rectangle.getWidth() / 2), rectangle.getHeight());
        JideSwingUtilities.fillGradient(graphics, top, startColor, middleColor, isVertical);
        JideSwingUtilities.fillGradient(graphics, bottom, middleColor, endColor, isVertical);
    public static void fillGradient(Graphics2D graphics, Component component, Color startColor, Color middleColor, Color endColor, boolean isVertical) {
        fillGradient(graphics, rectangle, startColor, middleColor, endColor, isVertical);
Skjalg
Re: Gradient fill in JideSwingUtilities
Postby JIDE Support » Fri Jan 15, 2010 9:18 am
Thanks for those nice codes. However, we have to try our best to reduce the exposed APIs we provided to our customers as much as possible while adding new features continuously. That's why we will leave those methods for our customers to accomplish. We will refer them to this thread if any other customers are interested in similar features.
