Dockable CollapsiblePane(s)
Postby Skjalg » Mon Dec 07, 2009 7:12 am
I am currently learning how to use the Docking and actions framework you have made. I was wondering if it was possible to beeing able to drag and drop CommandBars into the CollapsiblePanes and visa versa. I would like this feature instead of dragging the toolbar to the side and creating a vertical toolbar.
My current setup has toolbars at the top or bottom, and a CollapsiblePanes menu at the right hand (like in your demos), I'd like the ability to drag and drop a commandbar from the top to the right hand and then create a CollapsiblePane from a CommandBar. Also beeing able to rearrange the CollapsiblePane's inside the CollapsiblePanes would be great (using Dockable handling with drag, drop and outlining).
Skjalg
Re: Dockable CollapsiblePane(s)
Postby JIDE Support » Mon Dec 07, 2009 9:50 am
You may take a look at JIDE Dashboard. It is kind of drag-n-droppable CollapsiblePane(s). It could have multiple columns but you can set the column to 1 then it would be just one column like CollapsiblePanes.
You would have to implement the "dragging command bar to become collapsible pane" feature yourself.
Postby Skjalg » Tue Dec 08, 2009 5:37 am
Alright, thanks :)
Skjalg
