To customize the menu items in QuickTableFilterField
Postby Nachiyappan » Tue Oct 06, 2009 11:54 pm
Hi All,
I have created a table with 16 columns and give the table model to QuickTableFilterField to apply filter.
JPanel quickSearchPanel = new JPanel(new FlowLayout(FlowLayout.LEADING));
filterField = new QuickTableFilterField(sortTableModel);
filterField.setObjectConverterManagerEnabled(true);
quickSearchPanel.add(filterField);
The popup menu of QuickTableFilterField shows all the 16 columns for filtering. I need to optimize the menu items. Basically I dont like to like to show all the columns in QuickTableFilterField's popup menu. How can I achieve this?
Also I need to know to remove case sensitive, case insensitive, use wild cards menu item from QuickTableFilterField's popup menu...
Nachiyappan
Re: To customize the menu items in QuickTableFilterField
Postby Nachiyappan » Wed Oct 07, 2009 3:38 am
We can achieve the above by using setColumnIndices(arg).
Nachiyappan
Postby Nachiyappan » Wed Oct 07, 2009 3:39 am
How can I remove case sensitive, case insensitive, use wild cards menu item from QuickTableFilterField's popup menu...
Nachiyappan
Postby JIDE Support » Wed Oct 07, 2009 7:24 am
You can completely customize the popup menu by overriding createContextMenu method. You can either create your own popup menu or call super first to get the default one then add/remove menu items to/from it. All menu items we added have a name specified so you know which menu item it is when iterating through all the menu items. You can see what the names are in debugger.
Postby Nachiyappan » Wed Oct 07, 2009 9:08 pm
Could you pls give a sample code to customize the popupmenu of QuickTableFilterField.
1. Can we do search operation in two different tables using QuickTableFilterField? If so, in what way?
2. I have used setColumnIndices(new int[]{}).
code snippets:
filterField.setSearchingText(null);
filterField.setTableModel(sortableTableModel2);
sortableTable2.setModel(filterField.getDisplayTableModel());
filterField.setColumnIndices(new int[]{});
This display only "All" menu item with check state, instead of displaying all the column headers. But the operation of searching is not working properly. Eventhough I gave the exact value in column, it didnt show the record. Please explain.
Nachiyappan
Postby JIDE Support » Wed Oct 07, 2009 9:11 pm
One QuickTableFilterField can only serve one table. The search will done only on the columns that are specified in the setColumnIndices. Since you set it to empty, of course no rows will be kept.
To customize the popup menu, please try the following code.
        filterField.setPopupMenuCustomizer(new LabeledTextField.PopupMenuCustomizer() {
            public void customize(LabeledTextField field, JPopupMenu menu) {
                 // do operation here
Postby Nachiyappan » Wed Oct 07, 2009 9:51 pm
ok. Thanks.
Is there any option to use only "All" menu item, without setting empty in setColumnIndices().
Nachiyappan
Postby JIDE Support » Wed Oct 07, 2009 10:34 pm
You will have to use PopupMenuCustomizer to remove those menu items.
Postby Nachiyappan » Wed Oct 07, 2009 10:46 pm
To customize, I need to use PopupMenuCutomizer. ok.
Is there any option to set only "All" menu item?
Nachiyappan
Postby JIDE Support » Wed Oct 07, 2009 10:59 pm
I guess I didn't quite get your question. You setColumnIndex to null, then PopupMenuCustomizer to remove all menu items that represent each column, then you will only have "All" menu item left. Is that what you want?
Postby Nachiyappan » Wed Oct 07, 2009 11:42 pm
Yes, I want this. But this can achieve in two ways.
1. I can set empty array in setColumnIndices()
2. I can set null in setColumnIndices().
Both will remove all the table columns and menu item "All" only left.
I have "456", "467", "432" as values in one column. I tried to filter "432". Once, I typed "4" in that filterfield, all the rows are removed from the table. No records displayed, even i give "432". Why?
Nachiyappan
Postby Nachiyappan » Wed Oct 07, 2009 11:49 pm
Sorry, by setting null to setColumnIndices() is displaying all the menu items with menu item "All"
code snippets:
Now, the popup menu item display only menu item "All". But, it didnt work properly as i explained in my previous post.
Nachiyappan
Postby JIDE Support » Thu Oct 08, 2009 8:36 am
setColumnIndices() means the columns passed into the method will be filtered as our java doc explained. If you invoke the method with parameter null, that means all columns will apply the filter. If you invoke the method with a null array, that means no column will apply the filter hence no record will match whatever you input.
To achieve your goal, you need set ColumnIndices(null) then invoke setPopupMenuCustomizer() to remove all menu items except "All". Actually you don't even have to have "All" there. Maybe you can just clear all the menu items like the following.
                 menu.removeAll();
Postby Nachiyappan » Tue Oct 27, 2009 10:12 pm
Hi..
To remove all the items from popupmenu, we can use removeAll(). Instead, I need to remove only tablecolumns & "Keep parent row, if any children match" menu items from popup menu items. I have tried the following code to remove tablecolumns menu item. But it is not worked out.
fSearchField.setPopupMenuCustomizer(new LabeledTextField.PopupMenuCustomizer() {
for(int i=0; i <= fTableModel.getColumnCount(); i++){
menu.remove(2);
Kindly let me know to remove table column menu items & some specific default columns from popupmenu item.
The remove() contains, parameter as index or component. I want to know the index of the menu items, i want to remove. Else, component.
Nachiyappan
Postby JIDE Support » Tue Oct 27, 2009 11:39 pm
The index of the menu items are in the same order of the visible UI. I tried the following test case and it works fine to me. Please be noted that the separator is also a component need to be counted for indexing.
 * @(#)AutoFilterTreeTableDemo.java 4/10/2007
 * Copyright 2002 - 2007 JIDE Software Inc. All rights reserved.
import com.jidesoft.converter.ConverterContext;
import com.jidesoft.converter.PercentConverter;
import com.jidesoft.grid.*;
import com.jidesoft.swing.*;
import javax.swing.table.TableModel;
import javax.swing.table.TableCellRenderer;
import javax.swing.table.TableCellEditor;
import java.io.BufferedReader;
import java.io.IOException;
import java.io.InputStream;
import java.io.InputStreamReader;
import java.text.DateFormat;
import java.text.ParseException;
import java.text.SimpleDateFormat;
import java.util.ArrayList;
import java.util.Date;
import java.util.List;
import java.util.Random;
import java.util.zip.GZIPInputStream;
 * Demoed Component: {@link com.jidesoft.grid.SortableTable} <br> Required jar files: jide-common.jar, jide-grids.jar
 * <br> Required L&F: any L&F
public class AutoFilterTreeTableDemo extends AbstractDemo {
    private AutoFilterTableHeader _header;
    TreeTable _table;
    StyledLabel _filterTimesLabel;
    int _filterAppliedRowCount = 0;
    private static final long serialVersionUID = -3465282473768757260L;
    public AutoFilterTreeTableDemo() {
    public String getName() {
        return "AutoFilterTableHeader (TreeTable) Demo";
    public String getProduct() {
        return PRODUCT_NAME_GRIDS;
        return "This is a demo of QuickTableFilterField, AutoFilterTableHeader working with FilterableTreeTableModel.\n" +
                "\n" +
                "Demoed classes:\n" +
                "com.jidesoft.grid.FilterableTreeTableModel\n" +
                "com.jidesoft.grid.QuickTableFilterField\n" +
                "com.jidesoft.grid.AutoFilterTableHeader";
        JPanel checkBoxPanel = new JPanel(new GridLayout(0, 1));
        JCheckBox autoFilterCheckBox = new JCheckBox("Auto Filter");
        autoFilterCheckBox.addItemListener(new ItemListener() {
                _header.setAutoFilterEnabled(e.getStateChange() == ItemEvent.SELECTED);
        autoFilterCheckBox.setSelected(_header.isAutoFilterEnabled());
        JCheckBox showFilterNameCheckBox = new JCheckBox("Show Filter Name on Header");
        showFilterNameCheckBox.addItemListener(new ItemListener() {
                _header.setShowFilterName(e.getStateChange() == ItemEvent.SELECTED);
        showFilterNameCheckBox.setSelected(_header.isShowFilterName());
        checkBoxPanel.add(autoFilterCheckBox);
        checkBoxPanel.add(showFilterNameCheckBox);
        AbstractAction buttonActionAddRowsSelection = new AbstractAction() {
            private static final long serialVersionUID = 8642469359405934615L;
                int rowIndex = _table.getSelectedRow();
                if (rowIndex == -1) {
                    return;
                int actualRowIndex = TableModelWrapperUtils.getActualRowAt(_table.getModel(), rowIndex, TaskTreeTableModel.class);
                TaskTreeTableModel treeModel = (TaskTreeTableModel) TableModelWrapperUtils.getActualTableModel(_table.getModel(), TaskTreeTableModel.class);
                Row selectedRow = treeModel.getRowAt(actualRowIndex);
                treeModel.addRows(selectedRow, generateRows());
        buttonActionAddRowsSelection.putValue(Action.NAME, "Add 3 rows under selected row");
        JButton addRowsSelection = new JButton("Add 3 rows under selected row");
        addRowsSelection.setAction(buttonActionAddRowsSelection);
        AbstractAction buttonActionAddRowsRandomlyInFirstLevel = new AbstractAction() {
            private static final long serialVersionUID = 5541737527210971348L;
                Random random = new Random();
                int position = random.nextInt() % ((Expandable) treeModel.getRoot()).getChildrenCount();
                if (position < 0) {
                    position += ((Expandable) treeModel.getRoot()).getChildrenCount();
                System.out.println("Added rows in the first level: " + position + "th place before: " + ((Row) ((Expandable) treeModel.getRoot()).getChildAt(position)).getValueAt(0));
                treeModel.addRows((Row) treeModel.getRoot(), position, generateRows());
        buttonActionAddRowsRandomlyInFirstLevel.putValue(Action.NAME, "Add 3 rows randomly in root level");
        JButton addRowsRandomlyInFirstLevel = new JButton("Add 3 rows randomly in root level");
        addRowsRandomlyInFirstLevel.setAction(buttonActionAddRowsRandomlyInFirstLevel);
        AbstractAction buttonActionAddRowsRandomlyInSecondLevel = new AbstractAction() {
            private static final long serialVersionUID = -3196338169833882776L;
                Row selectedRows;
                do {
                    int position = random.nextInt() % treeModel.getRowCount();
                    if (position < 0) {
                        position += treeModel.getRowCount();
                    selectedRows = treeModel.getRowAt(position);
                    if (selectedRows.getParent() == null) {
                        continue;
                    if ("Specification Stage".equals(((Row) selectedRows.getParent()).getValueAt(0))) {
                        continue;
                    if (selectedRows.getParent().getParent() == null) {
                        continue;
                    if (selectedRows.getParent().getParent().getParent() == null) {
                        break;
                while (true);
                System.out.println("Added rows in the second level after: " + selectedRows.getValueAt(0));
                treeModel.addRows(treeModel.getRowIndex(selectedRows), generateRows());
        buttonActionAddRowsRandomlyInSecondLevel.putValue(Action.NAME, "Add 3 rows randomly in second level");
        JButton addRowsRandomlyInSecondLevel = new JButton("Add 3 rows randomly in second level");
        addRowsRandomlyInSecondLevel.setAction(buttonActionAddRowsRandomlyInSecondLevel);
        AbstractAction buttonActionDeleteRow = new AbstractAction() {
            private static final long serialVersionUID = 312834050406084046L;
                    return;
                treeModel.removeRow(actualRowIndex);
        buttonActionDeleteRow.putValue(Action.NAME, "Delete the selected row(s)");
        JButton deleteRow = new JButton("Delete the selected row(s)");
        deleteRow.setAction(buttonActionDeleteRow);
        AbstractAction buttonActionUpdateRow = new AbstractAction() {
            private static final long serialVersionUID = -8355408386489933920L;
                    return;
                Row row = treeModel.getRowAt(actualRowIndex);
                row.setValueAt(0.5, 1);
                treeModel.fireTableRowsUpdated(actualRowIndex, actualRowIndex);
        buttonActionUpdateRow.putValue(Action.NAME, "Update the selected row percentage");
        JButton updateRow = new JButton("Update the selected row percentage");
        updateRow.setAction(buttonActionUpdateRow);
        checkBoxPanel.add(addRowsSelection);
        checkBoxPanel.add(addRowsRandomlyInFirstLevel);
        checkBoxPanel.add(addRowsRandomlyInSecondLevel);
        checkBoxPanel.add(deleteRow);
        checkBoxPanel.add(updateRow);
        return checkBoxPanel;
    private List<Task> generateRows() {
        DateFormat format = new SimpleDateFormat("dd/MM/yyyy kk:mm");
        Date date = new Date();
            date = format.parse("18/02/2009 17:49");
        catch (ParseException exception) {
            exception.printStackTrace();
        Task parentRow = new Task("Specification Stage", 0.8, 12, 3, date, date);
        Task childRow1 = new Task("Review documents", 0.9, 10, 5, date, date);
        Task childRow2 = new Task("Create documents", 1, 17, 8, date, date);
        parentRow.addChild(childRow1);
        parentRow.addChild(childRow2);
        parentRow.setExpanded(true);
        List<Task> rows = new ArrayList<Task>();
        rows.add(parentRow);
        return rows;
        List list = createTaskList();
        if (list == null) {
            return new JLabel("Failed to read Project.txt.gz");
        final TaskTreeTableModel tableModel = new TaskTreeTableModel(list);
        QuickTableFilterField filterField = new QuickTableFilterField(tableModel);
                IFilterableTableModel displayTableModel = ((QuickTableFilterField) field).getDisplayTableModel();
                for (int i = 0; i < displayTableModel.getColumnCount(); i++) {
                    menu.remove(1);
        quickSearchPanel.setBorder(new JideTitledBorder(new PartialEtchedBorder(PartialEtchedBorder.LOWERED, PartialSide.NORTH), "QuickTableFilterField", JideTitledBorder.LEADING, JideTitledBorder.ABOVE_TOP));
        JPanel tablePanel = new JPanel(new BorderLayout(2, 2));
        tablePanel.setBorder(BorderFactory.createCompoundBorder(new JideTitledBorder(new PartialEtchedBorder(PartialEtchedBorder.LOWERED, PartialSide.NORTH), "Filtered Task List", JideTitledBorder.LEADING, JideTitledBorder.ABOVE_TOP),
                BorderFactory.createEmptyBorder(0, 0, 0, 0)));
        final JLabel label = new JLabel("Click on \"Auto Filter\" in option panel to enable AutoFilter feature");
        label.setHorizontalAlignment(SwingConstants.CENTER);
        label.setBorder(BorderFactory.createEmptyBorder(2, 0, 2, 0));
        SortableTreeTableModel sortableTreeTableModel = new StripeSortableTreeTableModel(new FilterableTreeTableModel(filterField.getDisplayTableModel()));
        sortableTreeTableModel.setDefaultSortableOption(SortableTreeTableModel.SORTABLE_LEAF_LEVEL);
        sortableTreeTableModel.setSortableOption(0, SortableTreeTableModel.SORTABLE_ROOT_LEVEL);
        sortableTreeTableModel.addIndexChangeListener(new IndexChangeListener() {
            public void indexChanged(IndexChangeEvent event) {
                if (event.getSource() instanceof FilterableTableModel && event.getType() == IndexChangeEvent.INDEX_CHANGED_EVENT && _filterTimesLabel != null) {
                    FilterableTableModel model = (FilterableTableModel) event.getSource();
                    _filterAppliedRowCount = model.retrieveFilterApplyRecords();
                    if (_filterAppliedRowCount != 0) {
                        StyledLabelBuilder.setStyledText(_filterTimesLabel, "Filter is applied on {" + _filterAppliedRowCount + ":f:blue} rows. {" + model.getRowCount() + ":f:blue} rows are left.");
                    else {
                        StyledLabelBuilder.setStyledText(_filterTimesLabel, "Filter in this level is cleared. {" + model.getRowCount() + ":f:blue} rows are shown up from the table model it wraps.");
        final TreeTable treeTable = new TreeTable(sortableTreeTableModel);
        _header = new CustomAutoFilterTableHeader(treeTable);
        _header.setAutoFilterEnabled(true);
        treeTable.setTableHeader(_header);
        // do not clear selection when filtering
        treeTable.setClearSelectionOnTableDataChanges(false);
        treeTable.setRowResizable(true);
        treeTable.setVariousRowHeights(true);
        treeTable.setShowTreeLines(false);
        treeTable.expandAll();
        treeTable.setPreferredScrollableViewportSize(new Dimension(700, 400));
        treeTable.getColumnModel().getColumn(0).setPreferredWidth(200);
        treeTable.getColumnModel().getColumn(3).setPreferredWidth(60);
        treeTable.getColumnModel().getColumn(4).setPreferredWidth(60);
        _table = treeTable;
        filterField.setTable(treeTable);
        JScrollPane scrollPane = new JScrollPane(treeTable);
        tablePanel.add(label, BorderLayout.BEFORE_FIRST_LINE);
        tablePanel.add(scrollPane);
        JPanel infoPanel = new JPanel(new BorderLayout(3, 3));
        _filterTimesLabel = new StyledLabel("Not filtered yet.");
        infoPanel.add(_filterTimesLabel);
        infoPanel.setBorder(BorderFactory.createCompoundBorder(new JideTitledBorder(new PartialEtchedBorder(PartialEtchedBorder.LOWERED, PartialSide.NORTH), "Filtered Row Count", JideTitledBorder.LEADING, JideTitledBorder.ABOVE_TOP),
        JPanel panel = new JPanel(new BorderLayout(3, 3));
        panel.add(quickSearchPanel, BorderLayout.BEFORE_FIRST_LINE);
        panel.add(tablePanel);
        panel.add(infoPanel, BorderLayout.AFTER_LAST_LINE);
        return panel;
    static class TaskTreeTableModel extends TreeTableModel implements StyleModel {
        private static final long serialVersionUID = 3589523753024111735L;
        public TaskTreeTableModel() {
        public TaskTreeTableModel(java.util.List rows) {
            super(rows);
        public int getColumnCount() {
            return 6;
        public ConverterContext getConverterContextAt(int rowIndex, int columnIndex) {
            if (columnIndex == 1) {
                return PercentConverter.CONTEXT;
            return super.getConverterContextAt(rowIndex, columnIndex);
        public Class<?> getCellClassAt(int rowIndex, int columnIndex) {
            return getColumnClass(columnIndex);
        public Class<?> getColumnClass(int columnIndex) {
            switch (columnIndex) {
                case 0:
                    return String.class;
                case 1:
                    return Double.class;
                case 2:
                case 3:
                case 4:
                    return Date.class;
                case 5:
                    return Date.class;
            return Object.class;
        public String getColumnName(int column) {
            switch (column) {
                case 0:
                    return "Task Name";
                case 1:
                    return "% Completed";
                case 2:
                    return "Duration";
                case 3:
                    return "Work";
                case 4:
                    return "Start";
                case 5:
                    return "Finish";
            return null;
        static CellStyle BOLD = new CellStyle();
        static {
            BOLD.setFontStyle(Font.BOLD);
        public CellStyle getCellStyleAt(int rowIndex, int columnIndex) {
            Row row = getRowAt(rowIndex);
            if (row.getParent() == getRoot() || (row instanceof ExpandableRow && ((ExpandableRow) row).hasChildren())) {
                return BOLD;
            return null;
        public boolean isCellStyleOn() {
            return true;
    private List createTaskList() {
        List rows = new ArrayList();
            InputStream resource = this.getClass().getClassLoader().getResourceAsStream("Project.txt.gz");
            if (resource == null) {
                return null;
            InputStream in = new GZIPInputStream(resource);
            BufferedReader reader = new BufferedReader(new InputStreamReader(in, "UTF-8"));
            Task[] tasks = new Task[3];
            do {
                String line = reader.readLine();
                if (line == null || line.length() == 0) {
                    break;
                String[] values = line.split(",");
                String name = "";
                double completed = 0.0;
                double duration = 0.0;
                double work = 0.0;
                Date startTime = new Date();
                Date endTime = new Date();
                if (values.length >= 1) {
                    name = values[0];
                if (values.length >= 2) {
                        completed = Double.parseDouble(values[1]);
                    catch (NumberFormatException e) {
                        e.printStackTrace();
                if (values.length >= 3) {
                        duration = Double.parseDouble(values[2]);
                if (values.length >= 4) {
                        work = Double.parseDouble(values[3]);
                if (values.length >= 5) {
                        startTime = format.parse(values[4]);
                    catch (ParseException e) {
                if (values.length >= 6) {
                        endTime = format.parse(values[5]);
                if (name.startsWith("++")) {
                    Task project = new Task(name.substring(2), completed, duration, work, startTime, endTime);
                    tasks[1].addChild(project);
                    tasks[2] = project;
                else if (name.startsWith("+")) {
                    Task task = new Task(name.substring(1), completed, duration, work, startTime, endTime);
                    tasks[0].addChild(task);
                    tasks[1] = task;
                else {
                    Task task = new Task(name, completed, duration, work, startTime, endTime);
                    rows.add(task);
                    tasks[0] = task;
            while (true);
            return rows;
        catch (IOException e) {
        return null;
    private static class Task extends DefaultExpandableRow {
        String name;
        double completed;
        double duration;
        double work;
        Date startTime;
        Date endTime;
        public Task() {
        public Task(String name, double completed, double duration, double work, Date startTime, Date endTime) {
            this.name = name;
            this.completed = completed;
            this.duration = duration;
            this.work = work;
            this.startTime = startTime;
            this.endTime = endTime;
        public Object getValueAt(int columnIndex) {
                case 0:
                    return name;
                case 1:
                    return completed;
                case 2:
                    return duration;
                case 3:
                    return work;
                case 4:
                    return startTime;
                case 5:
                    return endTime;
            return null;
        public void setValueAt(Object value, int columnIndex) {
                case 0:
                    name = "" + value;
                    break;
                case 1:
                    completed = (Double) value;
                    break;
                case 2:
                    duration = (Double) value;
                    break;
                case 3:
                    work = (Double) value;
                    break;
                case 4:
                    startTime = (Date) value;
                    break;
                case 5:
                    endTime = (Date) value;
                    break;
    class StripeSortableTreeTableModel extends SortableTreeTableModel implements StyleModel {
        private static final long serialVersionUID = 7707484364461990477L;
        public StripeSortableTreeTableModel(TableModel model) {
            super(model);
        protected final Color BACKGROUND1 = new Color(253, 253, 244);
        protected final Color BACKGROUND2 = new Color(255, 255, 255);
        CellStyle cellStyle = new CellStyle();
            cellStyle.setHorizontalAlignment(-1);
            cellStyle.setForeground(Color.BLACK);
            if (rowIndex % 2 == 0) {
                cellStyle.setBackground(BACKGROUND1);
            else {
                cellStyle.setBackground(BACKGROUND2);
            return cellStyle;
            return true;
        return "G27.AutoFilterTableHeader";
        showAsFrame(new AutoFilterTreeTableDemo());
    // This class doesn't do anything more than AutoFilterTableHeader. Just use it to demonstrate how you can override
    // AutoFilterBox to customize it.
    class CustomAutoFilterTableHeader extends AutoFilterTableHeader {
        public CustomAutoFilterTableHeader(JTable table) {
            super(table);
        protected TableCellRenderer createDefaultRenderer() {
            if (isAutoFilterEnabled()) {
                return new AutoFilterTableHeaderRenderer() {
                    protected void customizeList(JList list) {
                        super.customizeList(list);
                    protected void customizeAutoFilterBox(AutoFilterBox autoFilterBox) {
                        super.customizeAutoFilterBox(autoFilterBox);
                        CustomAutoFilterTableHeader.this.customizeAutoFilterBox(autoFilterBox);
                        autoFilterBox.applyComponentOrientation(CustomAutoFilterTableHeader.this.getComponentOrientation());
            else {
                return super.createDefaultRenderer();
        protected TableCellEditor createDefaultEditor() {
                return new AutoFilterTableHeaderEditor() {
                    private static final long serialVersionUID = -7347944435632932543L;
                    protected AutoFilterBox createAutoFilterBox() {
                        return new AutoFilterBox() {
            else {
                return null;
Postby Nachiyappan » Tue Dec 15, 2009 4:29 am
I need to avoid filtering in QuickTableFilterField, if my "xx" case get succeeded. Means that, if my "xx" case get succeeded, eventhough I give any value in QuickTableFilterField, the filter should not apply & all the rows should be displayed in table.
I have tried by setting parameter as new int[]{} for setColumnIndices(). Here no filter applied, but all the rows hidden from view.
Can you please let me the solution.
Nachiyappan
Postby JIDE Support » Tue Dec 15, 2009 7:52 am
Please try invoke QuickTableFilterField#setSearchingColumnIndices(int[]) to set a index array that does not contain any column index in the array you set by QuickTableFilterField#setColumnIndices(int[]).
To make it easier to use, we will change our project in 2.8.2 to make an empty array means no column to be searched.
Postby JIDE Support » Wed Dec 23, 2009 8:04 am
Just so you know, the meaning of QuickTableFilterField#setSearchingColumnIndices(new int[0]) is changed in both 2.8.2 and 2.7.7.
Postby monxla » Wed Jul 18, 2012 6:25 am
Hello All,
How can I remove Case sensitive and Case insensitive checked menu items?
Thanks of advance.
monxla
Postby JIDE Support » Wed Jul 18, 2012 9:18 am
Please override QuickTableFilterField#customizePopupMenu() to achieve your goal.
            protected void customizePopupMenu(JPopupMenu menu) {
                super.customizePopupMenu(menu);
                for (int i = menu.getComponentCount() - 1; i >= 0; i--) {
                    if ("Filter.caseSensitive".equalsIgnoreCase(menu.getComponent(i).getName()) ||
                            "Filter.caseInsensitive".equalsIgnoreCase(menu.getComponent(i).getName())) {
                        menu.remove(i);
                for (int i = menu.getComponentCount() - 1; i > 0; i--) {
                    // remove the redundant separator
                    if (menu.getComponent(i).getName() == null) {
                        if (menu.getComponent(i - 1).getName() == null) {
                            menu.remove(i);
Users browsing this forum: No registered users and 83 guests
