Auto-tips for obscured components
Postby efx » Thu Jun 18, 2009 2:55 am
It would be fantastic if you could provide a reasonably generic tool to support automatically displaying a tooltip-style popup over a component when part of the component is obscured due to layout, which shows the full component when mouse is over the obscured part of it.
An example of this common in many UIs including most IDEs is for JTree cells, e.g. in IntelliJ:
Obvious candidates are tree cell and list cell renderers, table cell renderers and JComboBox editor components.
I'm not sure if it would be possible to do this "unobtrusively", i.e. without having to subclass the tree/table/combobox, so e.g. you could just call static methods to install support...
AutoObscureTipSupport.install(myJTree);
AutoObscureTipSupport.install(myComboBox);
I realise it's quite a tall order!
efx
Re: Auto-tips for obscured components
Postby Walter Laan » Thu Jun 18, 2009 8:03 am
Walter Laan
Postby JIDE Support » Thu Jun 18, 2009 8:25 am
Thanks Walter. That's what I would suggest too. I tried it before. It is not as good as the one in intellij but should be good enough to use.
Postby efx » Thu Jun 18, 2009 9:39 am
Cool, almost exactly what I was looking for (except no support for JComboBox). I'll see if I can tweak it for combo boxes.
efx
Users browsing this forum: Baidu [Spider] and 94 guests
