DockableFrameFactory/DockableBarFactory in one class?
Postby rhinosoft » Thu Apr 23, 2009 8:52 am
Is there a way to implement "DockableFrameFactory" and "DockableBarFactory" in one class? Currently, I cannot due to compile time errors in the NetBeans IDE.
Example:
[code]
public class DockFactory implements DockableFrameFactory, DockableBarFactory
public DockFactory()
public DockableFrame create(String sKey)
DockableFrame frame = null;
return (frame);
public DockableBar create(String sKey)
DockableBar bar = null;
return (bar);
[/code]
rhinosoft
Re: DockableFrameFactory/DockableBarFactory in one class?
Postby JIDE Support » Thu Apr 23, 2009 9:30 am
You cannot do that as both method names are the same.
Postby rhinosoft » Thu Apr 23, 2009 10:13 am
I can do this alternative, but I prefer the other method. I understand that it would be too much trouble to change the interface b/c then all customers would have to change their code. But I thought I would ask in any case. Thanks.
[code]
DockableFrameFactory frameFactory = new DockFrameFactory() {
return (frame);
DockableBarFactory barFactory = new DockBaractory() {
return (bar);
[/code]
rhinosoft
Postby JIDE Support » Thu Apr 23, 2009 10:30 am
That's true. We probably should give a different method name initially but now it is too late to change.
