DualList vertical split has wrong icons in wrong alignment
Postby pentavalle » Tue Apr 21, 2009 3:45 am
If you set direction of a DualList to JideSplitPane.VERTICAL_SPLIT, the icons are aligned vertically, using a lot of space, but i think they should be aligned horizontally, to occupy less space and keep a better layout.
Icons and their text should be corrected too, "Move the selected items to the right" should become "Move the selected items to the bottom" and so on.
What do you think?
Andrea
pentavalle
Re: DualList vertical split has wrong icons in wrong alignment
Postby JIDE Support » Tue Apr 21, 2009 7:24 am
DualList doesn't really support vertical alignment. Many things have to be changed to make it working and we don't yet support it. I will make it a RFE.
Postby ananda.mishra » Wed Sep 28, 2011 4:35 am
IS DUALTABLE NOW SUPPORT VERTICAL ALIGMENT. PLEASE REPLY WHAT NEEDS TO BE DONE TO SPLIT TABLES VERTICALLY.
SETORIENTATION OF JSPLITPANE MAKES TABLE ALIGN VERTICALLY BUT BUTTONS TO MOVE ITEMS ARE AWKWARDLY PLACED.
ananda.mishra
Postby JIDE Support » Wed Sep 28, 2011 7:20 am
Please see the response at the other thread you initiated.
