JIDE supports custom search or not
Postby nivedita.jadhav » Thu Mar 19, 2009 2:00 am
I wanna clarification regarding JIDE grid feature whether that feature is available or not.
Can JIDE support some custom search (like in Outlook) ?
For example, if I type 1-A-3 is search it will search the entire table for that string. But if I give say AID:1-A-3, I would like to search only within one column (where AID is the column name).
Please let me know if this is possible in JIDE.
Thanks in advance,
Nivedita
nivedita.jadhav
Re: JIDE supports custom search or not
Postby JIDE Support » Thu Mar 19, 2009 7:11 am
FilterableTableModel has addFilter which you add a filter to any column or to a particular column. So if you can interpret the string user typed and call the correct addFilter method, it will work. You just have to do some extra work.
