.Net Compatible Formatting Library
Postby HolgerRasch » Thu Mar 12, 2009 2:29 am
My Idea is a .Net compatible Formatting library. My Problems with the default DecimalFormat are:
No thousands, billions support aso. .Net understand e.g. 1000000 as "#0," to display "1000" to display only thousands. I think In Java this is not possible.
A second problem with the "Default" DecimalFormat:
Is is not possible to set a "localized" FormatString (i.e. "#0." as German FormatPattern) to a Number and get the number by this pattern in another culture.
Example:
1'000'000 to format as "1,000 tsd" by the englisch UI-Culture. The used FormatPattern is a German "#0, tsd".
Idea: A .Net "CultureInvariant" compatible numberformat
Exchanging data between .Net and Java needs the agreement of a specific culture. .Net supports a cultureinvariant numberformat, java dosen't. Having such a library would be very helpful to write enterprise, multilingual applications that run the client under different languages / cultures.
I Know, that's not your main skills, but I think that's a nice idea for a great component.
HolgerRasch
Re: .Net Compatible Formatting Library
Postby JIDE Support » Thu Mar 12, 2009 11:56 am
Do you have a link to the document of the .net formatting library so that I can look at?
Postby HolgerRasch » Thu Mar 12, 2009 12:48 pm
Sure, that's the cultureInfo object (comparable to Location)
And here is an overview about supported format-strings
http://msdn.microsoft.com/en-us/library/427bttx3.aspx
HolgerRasch
Postby JIDE Support » Thu Mar 12, 2009 1:30 pm
I think NumberFormat pretty much supports most of the features mentioned. If is misses certain features, you may submit a bug report for Sun. This area is too detailed and focused. We are not very interested in doing it.
Postby HolgerRasch » Fri Mar 13, 2009 1:19 am
Thanks. I reported the bug to Sun. Maybe we get a new pattern support at the next java-version 8)
HolgerRasch
Users browsing this forum: Baidu [Spider] and 98 guests
