Visual Designer
Visual Designer
Postby nstn » Tue Feb 24, 2009 1:49 am
Is it possible to import components to Visual Designer? Is it possible to use Visual Designer like SWING plugin for Eclipse, using drug&drop. Is it possible to use in Visual Designer other JIDE components, not only frames and bars?
Regards
nstn
nstn
Re: Visual Designer
Postby JIDE Support » Tue Feb 24, 2009 7:51 am
It is not possible. Our Visual Designer is not intended to be a GUI builder. It just gives you the layout of DockableFrame or a CommandBar. You still use existing GUI builders to design the content pane of DockableFrame.
