Rootpane and look and feel
Postby lassiege » Sun Feb 15, 2009 3:12 am
I used jide a little for an evaluation and I'm very impressed about all the components and the strength of the API (even if it is sometimes quite easy to be lost ^^)
However I was quite frustrating about one little thing on the look and feel and I'm wondering if it could be a good suggestions to integrate this feature in Jide :
The rootpane is not modified with the look and feel (the top bar with close, maximize, iconize buttons). Is it possible to add some jide extensions to customize it ?
for example, something like synthetica does : http://www.javasoft.de/images/screensho ... vision.png
lassiege
Re: Rootpane and look and feel
Postby JIDE Support » Sun Feb 15, 2009 10:28 am
You may misunderstand the purpose of JIDE. JIDE is on the component side of the story, not on the L&F side. We don't provide any L&Fs. There are some Component UI classes in our library but that's mainly for JIDE specific components, not for standard Swing components. JRootPane is a standard Swing component. That's why we don't have any UI for it. We do this on purpose so that you can still use any existing 3rd party L&Fs in your application with JIDE extension on top of it.
Postby lassiege » Mon Feb 16, 2009 4:07 am
Ok thanks for your answer,
you're right I misunderstood it as I thought XERTO and other extensions was made to improve the standard look and feel (and it does ^^)
So I just made a try to use synthetica and I had some problem with some ClassnotfoundException on SyntheticaFrameborder:
            LookAndFeelFactory.addUIDefaultsInitializer(new SyntheticaInitializer());
            LookAndFeelFactory.addUIDefaultsCustomizer(new SyntheticaCustomizer());
            UIManager.put("Synthetica.window.decoration", Boolean.FALSE);
            UIManager.put("Synthetica.font.disabled", Boolean.FALSE);
            UIManager.setLookAndFeel(new SyntheticaWhiteVisionLookAndFeel());
java.lang.ClassNotFoundException: com.jidesoft.plaf.synthetica.SyntheticaFrameBorder
at java.net.URLClassLoader$1.run(URLClassLoader.java:200)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:268)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:164)
at com.jidesoft.plaf.LookAndFeelFactory$SyntheticaCustomizer.customize(Unknown Source)
at com.jidesoft.plaf.LookAndFeelFactory.installJideExtension(Unknown Source)
note that If I use TRUE in the following statement, the application can't be displayed :
That's too bad, this is the decoration that I would like to have ^^
but doesn't matter for the moment, I'll see later this point.
lassiege
Postby JIDE Support » Mon Feb 16, 2009 5:30 am
You just need to include jide-synthetica.jar in the classpath.
Postby odupouy31 » Tue Sep 08, 2009 2:13 am
I have exactly the same trouble using both JIDE and Synthetica (ClassNotFound exception for de.javasoft.plaf.synthetica.SyntheticaFrameBorder).
I add in my classpath jide (v.2.6.6), synthetica(v.2.8.3) and syntheticaAddons(v.0.9.8) but I didn't found jide-synthetica.jar...
Google didn't help so... may I ask where to find this .jar ? :)
Thanks for your help.
odupouy31
Postby JIDE Support » Tue Sep 08, 2009 8:01 am
The jide-synthetica.jar is under the lib folder in either evaluation package or the formal release package. I double checked and it is there. I am not sure why you can't find it.
Postby minnaheinonen » Wed Jul 28, 2010 6:35 am
Is this still the case? I couldn't find any jide-synthetica.jar package from the evaluation package.
minnaheinonen
Postby JIDE Support » Wed Jul 28, 2010 6:41 am
Please check it again. It should be there under lib folder.
Postby minnaheinonen » Thu Jul 29, 2010 2:31 am
Yeah, it was there. I was looking from a wrong package first... Thank you!
minnaheinonen
Users browsing this forum: Baidu [Spider] and 102 guests
