BallonTip won't show and freeze the Application
Postby Tobias.Steidle » Wed Jan 28, 2009 8:50 am
Hello I try to use BallonTip in my Application.
But when i execute the following Code, the Application freeze complete (on _ballontip.show(...)) and the BallonTip won't show.
What's going wrong?
      fPanel.getBtnTest().addActionListener(new ActionListener() {
               BalloonTip _balloontip; = new BalloonTip(createToolTipContent());
              _balloontip.show(fPanel.getBtnTest(), 0, 0);
    private JPanel createToolTipContent() {
        JPanel panel = new JPanel(new BorderLayout(12, 12));
        panel.setBorder(BorderFactory.createEmptyBorder(5, 5, 5, 5));
        panel.add(new JLabel("Test"));
        JPanel fieldPanel = new JPanel(new BorderLayout(6, 6));
        fieldPanel.setOpaque(false);
        fieldPanel.add(new JLabel("Name:"), BorderLayout.BEFORE_LINE_BEGINS);
        fieldPanel.add(new JTextField(20));
        panel.add(fieldPanel, BorderLayout.AFTER_LAST_LINE);
        panel.setOpaque(false);
        return panel;
Thanks in advance
Tobias.Steidle
Re: BallonTip won't show and freeze the Application
Postby JIDE Support » Wed Jan 28, 2009 11:14 am
I try your code and it works fine for me. Below is my testing code for your information. On one of my tests, it looks like the balloon tip was not shown when I set the position of the button in the top of the frame. However, it's actually hidden. Please try my code and feel free to let us know if you have any further issue.
import com.jidesoft.tooltip.BalloonTip;
public class BalloonTipTest {
    JButton ownerButton;
    public BalloonTipTest() {
        JFrame frame = new JFrame("Balloon Tip Test");
        JPanel panel = new JPanel(new GridBagLayout());
        panel.setPreferredSize(new Dimension(400, 400));
        ownerButton = new JButton("Click to show the Balloon Tooltip");
        ownerButton.setToolTipText("Click to show the Balloon Tooltip");
        ownerButton.addActionListener(new ActionListener() {
                BalloonTip _balloonTip = new BalloonTip(createToolTipContent());
                _balloonTip.show(ownerButton, 0, 0);
        panel.add(ownerButton);
        frame.getContentPane().setLayout(new BorderLayout());
        frame.getContentPane().add(panel, BorderLayout.CENTER);
        frame.setBounds(200,200,200,200);
        frame.pack();
        frame.toFront();
    public static void main(String args[]) {
        new BalloonTipTest();
        return panel;
Postby JIDE Support » Wed Jan 28, 2009 11:20 am
I would recommend you debug to see if fPanel.getBtnTest() is the right button you are expecting when _balloontip.show(JComponent, int, int) is invoked.
Postby Tobias.Steidle » Thu Jan 29, 2009 12:41 am
Hello your Testcode work's fine with JFrame but in my case i use a JInternalFrame instead a JFrame.
If i use the Button on an JInternalFrame the Application freeze complete.
JFrame -> Code works fine
JInternalFrame -> Application freeze (No exception, it still hangs)
Version of JIDE Components is 2.4.8
Tobias.Steidle
Postby JIDE Support » Thu Jan 29, 2009 8:38 am
Could you please make a test case for it and post it here?
Postby Tobias.Steidle » Thu Jan 29, 2009 11:15 pm
Here's the Testcode you requested.
           JFrame lRrame = new JFrame("Balloon Tip Test");
            lRrame.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
            JPanel lPanel = new JPanel(new GridBagLayout());
            lPanel.setPreferredSize(new Dimension(400, 400));
            lPanel.add(ownerButton);
            lRrame.getContentPane().setLayout(new BorderLayout());
            JDesktopPane lPane = new JDesktopPane();
            JInternalFrame lInternalFrame = new JInternalFrame();
         lInternalFrame.setSize(400,300);
         lInternalFrame.setLocation(20,20);
         lInternalFrame.setClosable(true);
         lInternalFrame.getContentPane().add(lPanel, BorderLayout.CENTER);
         lInternalFrame.setVisible(true);
         lPane.add(lInternalFrame);
         lRrame.setPreferredSize(new Dimension(500, 500));
            lRrame.getContentPane().add(lPane, BorderLayout.CENTER);
            lRrame.setBounds(200,200,200,200);
            lRrame.pack();
            lRrame.setVisible(true);
            lRrame.toFront();
            return panel;
Tobias.Steidle
Postby JIDE Support » Fri Jan 30, 2009 12:04 am
Thanks for the test case. I reproduced it and fixed it in JideSwingUtilities.java. It is checked in to open source JCL already. I will let you know when it is released.
Postby Tobias.Steidle » Fri Jan 30, 2009 1:08 am
Thanks a lot for your help
Tobias.Steidle
Postby JIDE Support » Mon Feb 02, 2009 8:03 pm
Just so you know, this is fixed in 2.5.1 which was just released.
Postby Tobias.Steidle » Tue Feb 03, 2009 12:19 am
hate to say it, but I've tried it with 2.5.1 and have still the same problem.
Tobias.Steidle
Postby JIDE Support » Tue Feb 03, 2009 8:38 pm
Sorry about that. I checked JideSwingUtilities.java (in open source JIDE Common Layer) and noticed the changed was overwritten by mistake. I fixed it again. You may grab it from SVN and do a build yourself if you need it urgently.
Users browsing this forum: Baidu [Spider] and 57 guests
