by abiffmaster » Mon Jan 12, 2009 1:31 pm
Treetable node doesn't expand on double click.
Only expands when you click the + icon....
The root works but all nodes under the root that have children do not respond to double clicks...
Any ideas? Do I need to add listeners etc and do this manually?
abiffmaster
by JIDE Support » Mon Jan 12, 2009 2:01 pm
I just tried myself and it works for me. Do you call setDoubleClickEnabled(false) by any chance? The flag is true by default.
by abiffmaster » Mon Jan 12, 2009 2:23 pm
No.... setDoubleClickEnabled is set to true.... Like I said... it works for the root node.... but does not work on any of the children nodes... Do the children nodes work for you?
abiffmaster
by JIDE Support » Mon Jan 12, 2009 2:29 pm
I did try children nodes and they expand as well. You can give FileSystemTreeTableDemo a try.
by abiffmaster » Mon Jan 12, 2009 2:37 pm
Thanks I will look into it. We extended this class so we more than likely broke something.
abiffmaster
Users browsing this forum: Baidu [Spider] and 98 guests
