BannerPanel with 2 icons
Postby flyerfred » Fri Dec 12, 2008 4:45 am
I am using BannerPanel objects to create headers in some dialogs. From my point of view, it would be nice to be able to set 2 icons in this panel (icons or components). A use case would be to set an icon on the left side of the title, and a component on the right side (this is actually my need).
Then the API could have a method public void setIconComponent(JComponent iconComponent, int location), where location could be set to SwingConstant.EAST or SwingConstant.WEST.
Thank you,
BR - Frédéric Tardieu
flyerfred
Re: BannerPanel with 2 icons
Postby JIDE Support » Fri Dec 12, 2008 8:53 am
BannerPanel is open source so feel free to change it to fit your need. If the change is general, feel free to contribute back.
There is setTitleIconLocation method to adjust the icon position. The value could be SwingConstants.TRAILING or SwingConstants.LEADING (or EAST and WEST). In fact you can also call getTitleLabel and cast it to JLabel and set your own icon. Since it is open source, you can see exactly how it is implemented and extend it to fit your need.
Users browsing this forum: Baidu [Spider] and 99 guests
