Tooltipes
Tooltipes
Postby joaquin.ruiz » Fri Oct 17, 2008 6:34 am
Hi, ¿is it possible to set a tooltip on pivotFields? I have try with the method setDescription but it doesn´t work.
joaquin.ruiz
Re: Tooltipes
Postby JIDE Support » Fri Oct 17, 2008 8:31 am
I guess it is because you must call setDescription before passing the PivotDataModel to PivotTablePane. I will fix it so that it can be set later.
Re: Tooltipes
Postby joaquin.ruiz » Mon Oct 20, 2008 3:25 am
thanks. it´works!!!!
joaquin.ruiz
Re: Tooltipes
Postby JIDE Support » Fri Oct 31, 2008 6:21 pm
Just so you know, this bug is fixed in 2.4.4 release so that even you call it after the PivotTablePane is created.
