Jide Components in IntelliJ GUI Builder
Postby pottsj » Tue Mar 08, 2005 8:36 am
I would be great to be able to use jide components in the intellij gui builder. In perticular things like the collapsible panes.
There seems to be two parts:
    * Getting Licencing to work:
    At the moment using jide components in the gui builder causes anoying licencing popups at random times during loading/building/coding etc.
    * Creating a standard xml config file for IntelliJ
pottsj
Postby JIDE Support » Tue Mar 08, 2005 9:14 am
Thanks for the suggestion. We actually have created a xml config for IntelliJ. It's easy to finish it up and release it. The harder part is your first part. We haven't figured out a way to get around it as we don't know the inside of GUI builder. Not just IntelliJ, the same issue with all other GUI builders.
