TableScrollPane Problem / scrollbar reinitialization
Postby lionel » Wed Jun 18, 2008 5:08 am
Here is the bug, you can even see it in your demo:
When you move one column, the horizontal scrollbar goes back to its start position.
Here is how to reproduce it:
Open TableScrollPane in your demo.
Put the horizontal scroll bar to the right.
Choose a column.
Try to move it.
And you'll see the scrollbar going left....
lionel
Postby JIDE Support » Wed Jun 18, 2008 7:25 am
I didn't notice this. I am on the latest 2.2.8 release if that matters.
Postby lionel » Wed Jun 18, 2008 8:01 am
I'm using webstart, so I believe you set the last versions on you repository...
lionel
Postby JIDE Support » Wed Jun 18, 2008 8:08 am
It is the latest. I can reproduce it using webstart as well as JDK5 is used. I don't think it is related to webstart but the JDK version. Locally I ran JDK6 and it works fine. I won't bother it too much as it is obviously a JDK thing. I will still double check our code to make sure it is.
Postby lionel » Wed Jun 18, 2008 8:08 am
BTW how can I know which version I'm using when I'm on your demo ?
lionel
Postby JIDE Support » Wed Jun 18, 2008 8:11 am
You can't tell but it is always the latest. Strange thing is I can't reporduce it using JDK5 locally either. I can hardly believe it is related to webstart. Which JDK are you on when you run webstart?
Postby lionel » Wed Jun 18, 2008 8:15 am
I run webstart with 1.6.0_03 java version
lionel
Postby lionel » Wed Jun 18, 2008 8:41 am
But I have also the same problem locally using jdk 1.6.0_03.
But it only happens on TableScrollPane, when I use normal Table, I don't have this problem...
lionel
Postby lionel » Fri Jun 20, 2008 2:29 am
Have you made any new tests ??
Does it works ?
lionel
Postby JIDE Support » Fri Jun 20, 2008 7:35 am
No, I haven't. I couldn't reproduce it on either JDK 5 or JDK 6 which I debug.
