RowTableSelection and CommandBar
Postby djdj » Thu Jun 05, 2008 7:24 pm
I have a dockable frame including a sortable table and command bar.
My problem is:
One the frame is displayed, the first row in the table is selected but the background of the title bar command is not set. However, it's only set when i select the row by clicking on it.
Please, can you help on this issue.
THANKS.
djdj
Postby JIDE Support » Thu Jun 05, 2008 7:42 pm
This bug should be fixed in the latest 2.2.7. If you are on an older release, you can call dockingManager.setAutoActivateFocusOwner(false) for now before upgrading.
Postby djdj » Fri Jun 06, 2008 11:10 am
Thanks for your reply.
First, I'm use only a dockable frame, and I'm calling dockableFrame.setFocusCycleRoot(false).
For my app., I'm not using docking manager.
djdj
Postby JIDE Support » Fri Jun 06, 2008 11:34 am
It won't work in that case. We don't expect people to use DockableFrame w/o DockingManager.
