Use mouse wheel to scroll tabs
Postby Radu » Thu Dec 27, 2007 3:55 am
When editing a large number of documents, it would be useful for the tab strip to be scroll-wheel sensitive
I.e. when there are more documents open than fit in the tab strip, the scroll wheel could be used to scroll left/right as is currently accomplished with the two arrows at the right.
Radu
Radu Coravu
<oXygen/> XML Editor, Schema Editor and XSLT Editor/Debugger
http://www.oxygenxml.com
Radu
Postby JIDE Support » Thu Dec 27, 2007 9:05 am
It is a good feature to add.
Postby JIDE Support » Thu Dec 27, 2007 10:02 pm
I added this feature to JideTabbedPane and checked in to JIDE Common Layer. It will take a while before we have next release as it is holiday in US but you can get it from JIDE Common Layer and play with it if you want.
Postby JIDE Support » Mon Jan 07, 2008 11:51 am
Just so you know, this is fixed in 2.2.1.08.
Users browsing this forum: Baidu [Spider] and 94 guests
