Disabling/Hiding CheckboxTree
Postby thegame1921 » Mon Dec 17, 2007 8:02 am
The program I am working on has recently switched from a JTree to a JIDE checkbox tree. The tree is only 3 levels deep with the first being the root which is hidden in the GUI.
What I'm looking to do is somehow stop users from selecting a node at the second level if that node has no children. I was wondering if there is some way to either hide the checkbox for that node or disable it so the user cannot select it.
thegame1921
Postby JIDE Support » Mon Dec 17, 2007 8:33 am
You can override isCheckBoxVisible method and return false for TreePath that you don't want to show the check boxes.
Postby thegame1921 » Mon Dec 17, 2007 9:07 am
I have tried this but it doesn't seem to be working for me. Where should it be overridden at? The node? CellRenderer? None of the above?
thegame1921
Postby JIDE Support » Mon Dec 17, 2007 9:08 am
Its method on CheckBoxTree.
Postby naseh11 » Thu Jul 31, 2008 2:23 am
Thanks for the support. it helps me alot.
To hide checkbox from all nodes except leaf ones:
CheckBoxTree tree = new CheckBoxTree(new DefaultTreeModel(rootNode))
public boolean isCheckBoxVisible(TreePath path)
return(((TreeNode)path.getLastPathComponent()).isLeaf());
naseh11
