AutoCompletion ListComboBox
Postby haer » Tue Nov 13, 2007 2:40 pm
I tried to combine a ListComboBox with AutoCompletion because I needed the resizing feature of the list itself. I extended the AutoCompletionDemo class with the following code, but when I run the demo, I get the error below.
private JPanel createPanel1() {
    ListComboBox listComboBox = new ListComboBox(_fontNames);
    ListComboBoxSearchable searchable = new ListComboBoxSearchable(listComboBox);
    JTextComponent textComponent = (JTextComponent)(listComboBox.getEditor().getEditorComponent());
    AutoCompletion ac = new AutoCompletion(textComponent, searchable);
Here is the error:
Exception in thread "main" java.lang.NullPointerException
   at com.jidesoft.combobox.ListComboBoxSearchable.getSelectedIndex(Unknown Source)
   at com.jidesoft.swing.Searchable.findFromCursor(Unknown Source)
   at com.jidesoft.swing.AutoCompletion$AutoCompletionDocument.insertString(Unknown Source)
   at javax.swing.text.AbstractDocument.replace(AbstractDocument.java:655)
   at javax.swing.text.JTextComponent.setText(JTextComponent.java:1693)
   at com.jidesoft.swing.AutoCompletion.configureEditor(Unknown Source)
   at com.jidesoft.swing.AutoCompletion.installListeners(Unknown Source)
   at com.jidesoft.swing.AutoCompletion.<init>(Unknown Source)
   at AutoCompletionDemo.createPanel1(AutoCompletionDemo.java:97)
   at AutoCompletionDemo.getDemoPanel(AutoCompletionDemo.java:55)
   at AbstractDemo.showAsFrame(AbstractDemo.java:56)
   at AutoCompletionDemo.main(AutoCompletionDemo.java:171)
When I leave out the last line, the normal ListComboBox is shown so I think there is no error because of an empty combobox or so.
Can you tell me, what's wrong? Or is it generally not possible to combine those features?
Greetings, Ronny
haer
Postby JIDE Support » Tue Nov 13, 2007 5:13 pm
The fix is to use
        AutoCompletion ac = new AutoCompletion(textComponent, _fontNames);
ListComboBoxSearchable shouldn't be used with AutoCompletion. Searchable is for non-editable combobox. AutoCompletion is for editable combobox. So they can't be used together. The NPE is because ListComboBoxSearchable will try to get the JList on the drop down panel but failed to create it as the UI is not finalized on the screen yet. I will add code to fix this but my fix above is the correct way to do this feature.
Postby JIDE Support » Fri Nov 16, 2007 3:54 am
Just so you know, we fixed this in 2.2.1.03 patch.
