setRowHeights method
Postby nicola.gioia » Wed Sep 05, 2007 12:36 am
In the JideTable there are some methods to manage the rowHeights of the JideTable.
When there is an invocation of the method setRowHeight that has the subsequent implementation:
public void setRowHeight(int rowHeight) {
        if (rowHeight <= 0) {
            throw new IllegalArgumentException("New row height less than 1");
        setRowHeights(null);
        super.setRowHeight(rowHeight);
        resizeAndRepaint();
The call of the method setRowHeights(null); in the previous part of code cause a destruction of the old _rowHeights value and a re-inizialization with a new instance.
This cause a destruction of all custom listener attacched to the old instance.
It is possible to change the setRowHeights(null) with somethimg similiar to t.getRowHeights().insertRows(0, t.getRowCount() , rowHeight);
I can't do it ovverriding the method because I can't have a direct access to the setRowHeight(int) of the JTable class without pass throught the setRowHeight(int) of the JideTable class (the first instruction after setRowHeights(null); is "super.setRowHeight(rowHeight);")
nicola.gioia
Postby JIDE Support » Wed Sep 05, 2007 8:08 am
I am not sure if that's the right way to do. If you call setRowHeight, it means you will NOT use rowHeights. At least this is what JTable does. There is a reason for it as using rowHeights to keep various row heights is an expensive thing. If your table has the same row height, it will be a lot of faster than the data is updating constantly.
This is very common that developers have to deal with. You can listen to property change listener on "rowHeights" and reinitialize. We did this kind of reinitialization in many places in our code when, for example, table model, table column model, is chagned.
Postby nicola.gioia » Thu Sep 06, 2007 6:52 am
Ok!
Thanks!
nicola.gioia
