Outlook Contacts Grid (list view)
Postby yezdi_m » Fri Aug 31, 2007 8:37 am
Hi Jidesoft,
Are there any plans to create a Outlook type Contacts grid as one of the Grid view.
Yezdi
yezdi_m
Postby JIDE Support » Fri Aug 31, 2007 9:10 am
GroupTable is the one that is supposed to be the outlook inbox table. You can check out GroupTableDemo from our examples folder.
Postby yezdi_m » Sun Sep 02, 2007 2:28 pm
Hi Jidesoft,
I wasn't talking about the Outlook Inbox Grid but the Outlook Contact. Its a JList with VERITCAL_WRAP. And each item can be considered as a row in a grid. So it should still have the TableModel as a Model.
Yezdi
yezdi_m
Postby JIDE Support » Sun Sep 02, 2007 3:28 pm
Sorry about that. I always thought about the inbox grid as many people asked for it before. As you said already, JList with VERITCAL_WRAP already can do something like the outlook contact list. You will need a special customized cell renderer for it. It's kind of like what we did in ImagePreviewList. I don't think it is a good idea to make it using JTable. JList is better.
