CheckBoxTree indeterminate/mixed state platform fidelity
Postby jaredmac » Fri Aug 03, 2007 11:47 am
We have our homegrown CheckBoxTree and the only reason we haven't cutover fully to JIDE's is the rendering of the indeterminate state checkboxes. On Windows XP L&F, the indeterminate state checkbox looks like a solid green square. On Vista, it looks like a grayish square with an outline. And on the Mac, it is a minus sign in a blue square.
JIDE's version shows the check with a gray background.
Would it be possible to integrate these L&F improvements into JIDE's CheckBoxTree? Thanks,
Jared
jaredmac
Postby JIDE Support » Fri Aug 03, 2007 11:50 am
If you could contribute your check box to us, we can certainly integrate it then you will get a nicer looking check box tree :-)
Users browsing this forum: Baidu [Spider] and 94 guests
