problem with setVariousRowHeights() method of JideTable
Postby nicola.gioia » Thu Jul 12, 2007 9:25 am
I tried to use the recently added setVariousRowHeights() method to allow my table to autoresize all the rows at same height.
Is seem to work fine if nobody call the setRowHeight method.
If i do a mouse resize to change the height of the rows and after this I invoke a method that programmatically change the height of the row calling the setRowHeight method the height of the rows of the table change correctly. The problem is that when i click on a cell the method mouseReleased present in the MouseInputAdapter of the class TableRowResizer reset the last size calculated by the mouse dragging.
I think it is a bug!
It is possible to notify to this class when a rowHeight change event occour?
nicola.gioia
Postby JIDE Support » Thu Jul 12, 2007 9:53 am
Can you send me a test case to reproduce the issue?
You can call getRowHeights().addRowHeightChangeListener to listen to row height change event.
Postby nicola.gioia » Fri Jul 13, 2007 12:32 am
Here is the code to reproduce the problem.
To see the problem do a resize by mouse dragging enlargeing the row height, then click on the button to resize the row, and finally click on a cell of the table.
you will see the table that autoresize all the row to the last height decided by mouse dragging.
import java.awt.event.*;
import java.beans.*;
import java.net.*;
import java.util.Vector;
import javax.swing.event.*;
import javax.swing.table.*;
import com.jidesoft.grid.*;
import com.jidesoft.swing.JideSwingUtilities;
public class JideTableThumbnail extends JideTable{
   protected CellResizeListener listener;
   protected boolean variousRowHeight;
   public JideTableThumbnail() {
      listener = new CellResizeListener(this);
      ThumbnailTableModel tm = new ThumbnailTableModel(listener);
      this.setModel(tm);
      this.setColumnModel(tm);
      getTableHeader().setVisible(true);
      setNonContiguousCellSelection(true);
      setAutoCreateColumnsFromModel(false);
      setAutoResizeMode(javax.swing.JTable.AUTO_RESIZE_OFF);
      setColumnResizable(true);
      setRowResizable(true);
      setRowHeight(50);
      setVariousRowHeights(false);
   public CellResizeListener getListener() {
      return listener;
      JFrame f = new JFrame("test");
      final JideTableThumbnail t = new JideTableThumbnail();
      JScrollPane sp = new JScrollPane(t);
      sp.addComponentListener(t.getListener());
      f.getContentPane().setLayout(new FlowLayout());
      f.getContentPane().add(sp);
      JButton b = new JButton("setRowHeight = 33");
      b.addActionListener(new ActionListener(){
            t.setRowHeight(33);
      f.getContentPane().add(b);
      f.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
      f.pack();
      System.out.println(f.getSize());
      JideSwingUtilities.globalCenterWindow(f);
      f.setVisible(true);
   public Vector<TableColumn> getColumns() {
      ThumbnailTableModel ttm = getThumbnailTableModel();
      if(ttm != null)
         return ttm.getColumnsVector();
      return null;
   public void updateColumnCount(int newColumnWidth) {
      int tableWidth = getWidth();
      if (getParent() instanceof JViewport) {
         JViewport v = (JViewport) getParent();
         tableWidth = v.getWidth();
      int columnCount = tableWidth/newColumnWidth;
      if(columnCount == this.getColumnModel().getColumnCount())
         return;
      if(columnCount == 0)
         return;
      if(columnCount > this.getColumnModel().getColumnCount()){
         for (int i = this.getColumnModel().getColumnCount(); i <  columnCount; i++) {
            this.getColumnModel().addColumn(((ThumbnailTableModel)this.getColumnModel()).buildColumn(i));
      }else if(columnCount < this.getColumnModel().getColumnCount()){
         for (int i = this.getColumnModel().getColumnCount() -1; i >= columnCount; i--) {
            this.getColumnModel().removeColumn(this.getColumnModel().getColumn(i));
      if(ttm != null){
         ttm.fireTableChanged(new TableModelEvent(ttm, TableModelEvent.HEADER_ROW));
         ttm.fireTableChanged(new TableModelEvent(ttm));
   public ThumbnailTableModel getThumbnailTableModel(){
      ThumbnailTableModel ttm = null;
      TableModel tm = getModel();
      if (tm instanceof SortableTableModel) {
         tm = ((SortableTableModel) tm).getActualModel();
      if (tm instanceof ThumbnailTableModel) {
         ttm = (ThumbnailTableModel) tm;
      }return ttm;
   class ThumbnailTableModel extends DefaultTableColumnModel implements TableModel{
      protected Vector<String> rows;
      protected Vector<TableModelListener> listeners;
      protected CellResizeListener resizeListener;
      public ThumbnailTableModel(CellResizeListener resizeListener) {
         this.resizeListener = resizeListener;
         tableColumns.clear();
         tableColumns.add(buildColumn(0));
         tableColumns.add(buildColumn(1));
         tableColumns.add(buildColumn(2));
         tableColumns.add(buildColumn(3));
         rows = new Vector<String>(12);
         rows.add("http://www.jidesoft.com/imgs/pht_s2.jpg");
         rows.add("http://www.jidesoft.com/imgs/125x125-JDJ.jpg");
         rows.add("http://www.jidesoft.com/imgs/pht_1.jpg");
         rows.add("http://www.jidesoft.com/imgs/pht_s6.jpg");
         rows.add("http://www.libero.it/img41/col3/top_box1/03/325/2007/5/banner_10.jpg");
         rows.add("http://www.libero.it/c/img69/hp/07/7/2007/6/cannavaro148.jpg");
         rows.add("http://www.libero.it/x/img48/02/2716/2007/6/motori_s.jpg");
         rows.add("http://www.libero.it/c/img69/hp/06/60/2007/6/dalemasei88.jpg");
         rows.add("http://thumbs.ebaystatic.com/pict/2901307386548080_1.jpg");
         rows.add("http://thumbs.ebaystatic.com/pict/2501365998908080_1.jpg");
         rows.add("http://tbn0.google.com/images?q=tbn:mVuW5icfsm2ZzM:http://www.flensburg-online.de/comics/pluto.gif");
         rows.add("http://www.flensburg-online.de/comics/pluto2.gif");
      public Vector<TableColumn> getColumnsVector(){
         return this.tableColumns;
      private TableColumn buildColumn(int index) {
         TableColumn c = new TableColumn();
         int preferredWidth = (tableColumns!= null && tableColumns.size() > 0)?tableColumns.get(0).getPreferredWidth():160;
         c.setPreferredWidth(preferredWidth);
         c.setModelIndex(index);
         c.addPropertyChangeListener(resizeListener);
         c.setCellRenderer(new MyTableCellRenderer());
         return c;
      public int getColumnCount() {
         return tableColumns.size();
      public void addTableModelListener(TableModelListener l) {
         if(listeners == null)
            listeners = new Vector<TableModelListener>();
         listeners.add(l);
      public void removeTableModelListener(TableModelListener l) {
         if(listeners != null)
            listeners.remove(l);
      public Class<?> getColumnClass(int columnIndex) {
         return Object.class;
      public String getColumnName(int columnIndex) {
         return (columnIndex>0 && columnIndex < tableColumns.size())?tableColumns.get(columnIndex).toString():null;
      public int getRowCount() {
         return rows.size()/getColumnCount()+(rows.size()%getColumnCount()==0?0:1);
      public Object getValueAt(int rowIndex, int columnIndex) {
         if(rowIndex*getColumnCount()+columnIndex < rows.size())
            return rows.get(rowIndex*getColumnCount()+columnIndex);
         return null;
      public boolean isCellEditable(int rowIndex, int columnIndex) {
      public void setValueAt(Object aValue, int rowIndex, int columnIndex) {}
      public void fireTableChanged(TableModelEvent e) {
         for (int i = listeners.size() - 1; i >= 0; i--) {
            listeners.get(i).tableChanged(e);
   class CellResizeListener extends ComponentAdapter implements PropertyChangeListener{
      protected JideTableThumbnail thumbTable;
      public CellResizeListener(JideTableThumbnail thumbTable) {
         this.thumbTable = thumbTable;
      public void propertyChange(PropertyChangeEvent evt) {
         Vector<TableColumn> columns = this.thumbTable.getColumns();
         if(columns == null)
            return;
         int updatedWidth = -1;
         if(evt.getPropertyName().equals("width") ){
            updatedWidth = (Integer)evt.getNewValue();
            for (int i = 0; i < columns.size(); i++) {
               TableColumn col  = columns.get(i);
               if(col.getWidth() != updatedWidth){
                  col.setWidth(updatedWidth);
         }else if(evt.getPropertyName().equals("preferredWidth")){
               if(col.getPreferredWidth() != updatedWidth){
                  col.setPreferredWidth(updatedWidth);
         ThumbnailTableModel ttm = thumbTable.getThumbnailTableModel();
         if(updatedWidth > 0)
            thumbTable.updateColumnCount(updatedWidth);
      public void componentResized(ComponentEvent e) {
         if(columns == null || columns.size()<1)
            return;
         updateColumnCount(columns.get(0).getWidth());
   class MyTableCellRenderer extends DefaultTableCellRenderer{
      public Component getTableCellRendererComponent(JTable table, Object value, boolean isSelected, boolean hasFocus, int row, int column) {
         Component argr = super.getTableCellRendererComponent(table, value, isSelected, hasFocus, row, column);
            if(value != null)
               setIcon(new ImageIcon(new URL(value.toString())));
            else
               setIcon(null);
         } catch (MalformedURLException e) {
            e.printStackTrace();
         setText("");
         return argr;
nicola.gioia
Postby JIDE Support » Fri Jul 13, 2007 7:48 am
I found the reason and fixed it. Thanks for the test case. I will let you know when the patch is available.
Postby JIDE Support » Mon Jul 23, 2007 12:14 am
Just so you know, this is fixed in 2.1.2 release.
Postby nicola.gioia » Tue Jul 24, 2007 6:02 am
ok, thanks
nicola.gioia
