Property Pane ++ ?
Property Pane ++ ?
Postby genscan » Wed Nov 03, 2004 6:37 am
The Property Pane is the most common way for dumping properties. But it is very "developer oriented", you never find this kind of presentation under Word..Excel..., and in the application I develop, users are a little bit confused, with this view.
Could you imagine a way to have another view of the property list ? for example, the category could be vertical tabs (like side pane), each property is not a row in a table but a property editor in a JPanel with a high design etc... (like in the last release of PhotoShop)
It's time to introduce a new standard ;-)
Genscan
genscan
Postby JIDE Support » Wed Nov 03, 2004 8:22 am
I like this idea. Will see what we can do here. Thanks.
Postby genscan » Wed Jun 01, 2005 3:45 am
Any news about this kind of property view ?
I see more and more graphical tools implementing this simplier view...
Thanks for your feedback.
genscan
Postby JIDE Support » Wed Jun 01, 2005 8:26 am
Actually I tried to look at Photoshop CS to see this property sheet you talked about but couldn't find it. Where do you get that screenshot?
Postby neadamthal » Tue Sep 13, 2005 7:36 am
has there been any progress on this??
i would have to agree that this format is better than the existing.
neadamthal
Postby JIDE Support » Tue Sep 13, 2005 8:20 am
We didn't do anything about it yet. As I said in this thread, I can't find it in Photoshop CS although genscan mentioned Photoshop. I really want to see it in action so that I can make the decision if we should make it a high priority.
Postby genscan » Wed Apr 05, 2006 2:27 am
Just a little update on this topic, cause I look at this property pane, and I think it's a good step for targeting end users.
genscan
Postby nicola.gioia » Wed Apr 05, 2006 9:36 am
if i use a propertyTable to update some object properties, can I have an event to eventually disable the confirm button when the property I editing have uncorrect format?
[/img]
nicola.gioia
Postby JIDE Support » Wed Apr 05, 2006 11:19 am
genscan, the hard part of this property table is to layout the form automatically. I guess you expect it, right? Otherwise, you can layout out the fields all by yourself manually.
nicola.gioia, I am not sure if I understand but I'll try. PropertyTableModel supports PropertyChangeListener. It will fire property change event when a Property in PropertyTableModel value changes because user changes the cell. I wonder if you can use this event to do things like disabling the confirm button.
BTW, you can start a new thread next time if the post is not related to the current discussion.
Postby pphiremath » Tue Oct 10, 2006 1:41 pm
I want to use PropertyTable stand alone (i.e. not inside a PropertyPane) and have no categories, how do i remove the 'misc' category that gets added.
Also how do I change the column header texts.
pphiremath
Postby JIDE Support » Tue Oct 10, 2006 1:48 pm
You just set to setOrder to PropertyTableModel.SORTED or UNSORTED to get rid of the category.
You can override getColumnName method in PropertyTableModel to change the header texts.
