pivotDataModel.calculate();
I have found another issue: If I drag and drop a row or column field (say "product") onto a field (say "sales") in the field list ...
I have another(!) issue/question: When I persist layout information using PivotTablePersistence, it appears not to persist which values have been ticked in the filter popups (ie. the filter settings). Is that correct?
You could give a test patch at http://www.jidesoft.com/downloads/jide.2.1.2.01.zip (or http://www.jidesoft.com/evaluation/jide ... 1.eval.zip if you are still evaluating) a try which should fix the filter popup disappearing problem.
I couldn't reproduce this problem. Can you reproduce it it in our demo?
Further, I also notice that if the user is re-sizing a column or row when fieldsUpdated is called, the re-sizing is stopped and the user has to let go of the mouse and start again. I don't suppose there is any way around this issue?
The width thing should be fixed already in the latest release. If not, please let me know.
panel.add(new JButton(new AbstractAction("Update") {
Thread runnable = new Thread() {
public void run() {
Thread.sleep(5000);
catch (InterruptedException e1) {
e1.printStackTrace();
Runnable runnable = new Runnable() {
public void run() {
System.out.println("updated");
_pivotTablePane.bothHeadersUpdated();
SwingUtilities.invokeLater(runnable);
runnable.start();
}));Further, I also notice that if the user is re-sizing a column or row when [bothHeadersUpdated] is called, the re-sizing is stopped and the user has to let go of the mouse and start again. I don't suppose there is any way around this issue?
