CheckBoxTree
CheckBoxTree
Postby pourmo » Mon May 07, 2007 7:59 am
Hi
I am using the CheckBoxTree Item and I want to know If there is a functionality where I can get All the TreePaths for the Nodes that have been ticked.
Many Thanks
Mo
pourmo
Postby JIDE Support » Mon May 07, 2007 8:28 am
The method is getCheckBoxTreeSelectionModel().getSelectionPaths(). Just rememeber all the methods related to check box states are on getCheckBoxTreeSelectionModel().
Postby pourmo » Mon May 07, 2007 9:12 am
Hi
I have a tree with a top node having 4 children. I tick the top node and then all the child nodes get ticked automatically. When I call
getCheckBoxTreeSelectionModel().getSelectionPaths() it returns me the reference to a single TreePath.
How can I find out the path to the selected checkboxes.
regards,
Mo
pourmo
Postby JIDE Support » Mon May 07, 2007 9:15 am
That's correct behavior. CheckBoxTree is in digin mode. Any parent path selected indicates all its children paths are selected. So no need to return all the children paths.
