Titled Panel
Titled Panel
Postby mdesai12 » Thu May 03, 2007 2:40 pm
SwingX has TitledPanel: JPanel with a built-in title bar. I believe the panel corners can be rounded. Is there something similar in JIDE? Thanks!
mdesai12
Postby JIDE Support » Thu May 03, 2007 2:54 pm
We didn't feel TitledPanel is generic enough to be a component. In certain case, you can use CollapsiblePane to do it and you can optionally disable the collapse feature if you want. In other cases, you can use BannerPanel on the north with content in the center to make such a UI.
Postby mdesai12 » Thu May 03, 2007 9:11 pm
That's what I thought. How can I make any of the corners rounded in a BannerPanel? Thanks.
mdesai12
Postby JIDE Support » Fri May 04, 2007 12:46 pm
Not there by default but you can override paintComponent method of BannerPanel to do it.
Users browsing this forum: No registered users and 35 guests
