Disable context menu in QuickFilterField
Postby jaredmac » Wed Apr 11, 2007 1:35 pm
We love the QuickFilterField but would like to disable the context menu (and thereby not have the down arrow show up).
We can disable the context menu by overriding createContextMenu to return null, but that still leaves us having to replace the icon (since it contains a down arrow).
Would this be an API enhancement you'd consider?
Jared
jaredmac
Postby JIDE Support » Wed Apr 11, 2007 1:41 pm
You can use setIcon method and set it to null.
Postby kenneth.orr » Thu Apr 12, 2007 4:13 am
We don't actually want the icon to be null, what we'd prefer is just the magnifying glass without the popup menu indicator (the arrow). This is similar to the search field provided on Mac OS X and Windows Vista.
We're really looking to replicate the OS widget as closely as possible.
-Ken
kenneth.orr
Postby JIDE Support » Thu Apr 12, 2007 8:55 am
You could set an icon that does not have the arrow as the arrow is part of the icon we use on the textfield.
Easiest way to get that icon probably is to extract it from our jar file (com/jidesoft/grid/icons/quick_search.png) and slice it properly.
Users browsing this forum: No registered users and 167 guests
