Saving In visual Designer
Postby ruslan » Mon Apr 02, 2007 9:50 am
It seems that the Visual Designer lost its ability to save layouts.
Save dialog pops up and "save" is clicked, but the file does not get written.
ruslan
Postby JIDE Support » Mon Apr 02, 2007 11:00 am
I can't reproduce it for some reason. Which version are you on? You can run java -jar jide-common.jar to see the version. Does it create a new file at all?
Postby ruslan » Mon Apr 02, 2007 11:33 am
I'm actually launching the designer via webstart from your page.
Here is the exception from the console after clicking "save" on the dialog box.
Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: org/apache/xml/serialize/OutputFormat
at com.jidesoft.designer.g.save(Unknown Source)
at com.jidesoft.designer.n.saveAsProject(Unknown Source)
at com.jidesoft.designer.a$5.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.AbstractButton.doClick(Unknown Source)
at com.jidesoft.plaf.vsnet.VsnetMenuItemUI.a(Unknown Source)
at com.jidesoft.plaf.vsnet.VsnetMenuItemUI$MouseInputHandler.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
ruslan
Postby JIDE Support » Mon Apr 02, 2007 11:48 am
Are you running JDK1.4.2? If so, you would need xerces.jar in the class path. If JDK5, we will use those class in JDK5 jar so no need for extra xerces.jar
Postby ruslan » Mon Apr 02, 2007 12:37 pm
ok thanks for the tip.. will try to resolve
FYI, Im using
java version "1.5.0_11"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_11-b03)
Java HotSpot(TM) Client VM (build 1.5.0_11-b03, mixed mode)
ruslan
Postby JIDE Support » Mon Apr 02, 2007 12:41 pm
Never mind. We did the switch as I mentioned in other places but not in visual designer. What happened is we bundled xerces.jar into jide_designer.jar in earlier release but for recent releases, we didn't bundle it. That's why it stops working. I'll fix it.
Postby JIDE Support » Mon Apr 02, 2007 10:34 pm
Just so you know, this should be fixed on the webstart verison.
Postby ruslan » Tue Apr 03, 2007 7:04 am
thank you!
ruslan
Postby jgindin » Wed Sep 19, 2007 8:17 am
I'm running 1.6.0.02, and having this same problem when trying to run:
java -jar jide-designer.jar
The webstart version *does* seem to work.
jgindin
Postby JIDE Support » Wed Sep 19, 2007 8:32 am
I'll fix it so that it doesn't depend on xerces classes. JDK6 included those classes already.
Users browsing this forum: Baidu [Spider] and 99 guests
