Drop Down Menu in Property Table
Postby vic.pro » Thu Mar 15, 2007 5:08 am
I am working on the drop down functionality for a property table cell. The drop down has a radio button and the text field. When I click on the radio [in the down menu], textfield gets enabled but cursor instead of showing in the text field is showing in the property table cell. the editor is based on abstract combobox.
vic.pro
Postby JIDE Support » Thu Mar 15, 2007 7:54 am
By default, we don't make the popup focus. To enable it, you must call popupPanel.setDefaultFocusComponent to a component in your popup such as the text field you mentioned.
Users browsing this forum: No registered users and 91 guests
