StyledLabel and backGround
Postby nicola.gioia » Wed Dec 13, 2006 4:59 am
I used the StyledLabel, to customize the font color , and if I use the setForeground method on the styledLabel it correctly change the color of the uncustomized part of the label.
But if I use the setBackBround method to change the background color it seems not work.
To reproduce the problem use the following code.
When you choose a new color the background color is set on both styledLabel and button.
import java.awt.event.*;
import com.jidesoft.combobox.ColorChooserPanel;
import com.jidesoft.icons.JideIconsFactory;
import com.jidesoft.swing.*;
public class StyledLabelBug {
      final JFrame f = new JFrame("StyledLabel Test");
      f.getContentPane().setLayout(new BorderLayout());
      final StyledLabel lab = new StyledLabel(JideIconsFactory.getImageIcon(JideIconsFactory.JIDE32));
      lab.setText("colored text");
      lab.setStyleRange(new StyleRange(0,7,StyleRange.STYLE_WAVED,Color.RED));
      f.getContentPane().add(lab,BorderLayout.WEST);
      final JButton b = new JButton("BackGround color ... ");
      b.addActionListener(new ActionListener(){
            ColorChooserPanel p = new ColorChooserPanel(ColorChooserPanel.PALETTE_COLOR_15);
            p.setVisible(true);
            final JDialog d = new JDialog(f,"color",true);
            d.getContentPane().setLayout(new BorderLayout());
            d.getContentPane().add(p,BorderLayout.CENTER);
            JButton close = new JButton("Close");
            close.addActionListener(new ActionListener(){
                  d.dispose();
            d.getContentPane().add(close,BorderLayout.SOUTH);
            d.setLocationRelativeTo(f);
            d.pack();
            d.setVisible(true);
            lab.setBackground(p.getSelectedColor());
      f.getContentPane().add(b,BorderLayout.CENTER);
      f.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
      f.pack();
      JideSwingUtilities.globalCenterWindow(f);
      f.setVisible(true);
Another problem regards the use of the styledLabel as treeCellRenderer because the Styled label often is cut at the end.
nicola.gioia
Postby nicola.gioia » Wed Dec 13, 2006 7:33 am
I resolved all problem...
For the renderer I used the StyledLabelTreeRenderer, and for the StyledLabel I called the setOpaque(true) method.
Thanks and sorry
nicola.gioia
Postby JIDE Support » Wed Dec 13, 2006 9:08 am
That's correct. StyledLabel, just like JLabel, is transparent by default.
