pixel to inch/cms conversion ...
Postby pphiremath » Wed Oct 11, 2006 5:50 pm
I am working on a ruler/scale that can be embeded inside scrollpane to track the mouse position on the document inside its viewport.
I am new to jide, I just want to know if there already was some widget that does something similar to this or some utility method that gives me a correct mapping from a pixel to inches/cms considering the current resolution of the screen.
pphiremath
Postby JIDE Support » Wed Oct 11, 2006 5:54 pm
No, we dont' have it. Sounds like an interesting component. If you made, maybe you can use it to exchange for a free JIDE license.
Postby Walter Laan » Thu Oct 12, 2006 1:03 am
We made a simple ruler based on Swing scroll demo, see Rule.java there.
Note that java Graphics assumes 72dpi, usually ignoring the OS/desktop dpi settings. So we just hardcoded the pixels per cm to
private static final double PPC = 28.3464; // pixels per centimer
Walter Laan
Postby JIDE Support » Thu Oct 12, 2006 7:09 am
Thanks for the link, Walter.
pphiremath, this demo should give you a good starting point.
