Problem with DefaultDialogDockableBarDockableHolder
Postby nicola.gioia » Fri Oct 06, 2006 6:59 am
When I use the DefaultDialogDockableBarDockableHolder class as a dialog on my application I have two problems:
    - The setModal(true) seems not have effect (the window created is not modal)
    - If i try to make floatable a CommandBar by mouse dragging I have problems because the mouse position differ from the CommandBar position once the commandBar become float
To reproduce the problem tou can try to use the above example:
import java.awt.event.*;
import com.jidesoft.action.*;
import com.jidesoft.swing.JideSwingUtilities;
public class DefaultDialogDockableBarDockableHolderBug extends DefaultDialogDockableBarDockableHolder {
   public DefaultDialogDockableBarDockableHolderBug(Frame parent) {
      super(parent);
      init();
   private void init() {
      getLayoutPersistence().setProfileKey("bug.test");
      getLayoutPersistence().beginLoadLayoutData();
      this.getDockableBarManager().addDockableBar(CommandBarFactory.createLookAndFeelCommandBar(this));
         JTextArea ta = new JTextArea("test test test test\n test test test test\n"+
               "test test test test\n test test test test\n");
         getDockingManager().getWorkspace().add(ta,BorderLayout.CENTER);
      getLayoutPersistence().loadLayoutData();
      final JFrame f = new JFrame("test");
      JButton b = new JButton("show dialog");
      b.addActionListener(new ActionListener(){
            DefaultDialogDockableBarDockableHolderBug b = new DefaultDialogDockableBarDockableHolderBug(f);
            b.setLocationRelativeTo(f);
            b.setModal(true);
            b.setDefaultCloseOperation(DISPOSE_ON_CLOSE);
            b.setVisible(true);
      f.getContentPane().add(b);
      f.pack();
      JideSwingUtilities.globalCenterWindow(f);
      f.setVisible(true);
nicola.gioia
Postby JIDE Support » Fri Oct 06, 2006 8:54 am
I believe setModal need to be called before the dialog is visible. What you probably don't know is loadLayoutData will make the dialog visible. So you can change the code to
      setModal(true);
Postby nicola.gioia » Mon Oct 09, 2006 1:28 am
Ok.
The problem of the CommandBar floated by mouse dragging?
nicola.gioia
Postby JIDE Support » Mon Oct 09, 2006 8:19 am
We can reproduce that problem and will try to fix for next patch release.
Postby JIDE Support » Mon Oct 09, 2006 12:59 pm
Just so you know, 1.9.3.02 is released which fixed this dragging command bar bug.
Postby nicola.gioia » Wed Oct 11, 2006 1:20 am
Thanks!
nicola.gioia
Users browsing this forum: No registered users and 35 guests
