CheckBoxTree Enhancements
Postby jaredmac » Tue Sep 19, 2006 6:56 am
We wanted to replace our internal CheckBoxTree with JIDE's version, but just noticed that it does not support a mix of checkbox nodes and non-checkbox nodes.
This is something worth considering when you have a tree that contains, e.g., group title nodes with checkboxes underneath.
Also, the rendering of the mixed-state node on WinXP could be improved -- a mixed state checkbox in MSWord renders as a green square, rather than a green check with a gray background.
Jared
jaredmac
Postby jaredmac » Tue Sep 19, 2006 6:59 am
Whoops, spoke a bit too soon. Looks like overriding the method
isCheckBoxVisible(TreePath path)
can accomplish what we want to do.
jaredmac
Postby JIDE Support » Tue Sep 19, 2006 8:03 am
Yes, that's the method you can use.
For the mixed-state check box, you are right. We simple used a disabled check box and renderer it as the 3rd state. Ideally we should make a special UI just for this. However then we need to do it for every L&F which is a little too much. Anyway, we will do it in the future.
