MouseWheelListener for DateSpinner
Postby arazvi » Thu Jul 27, 2006 5:46 am
It would be nice if you could scroll up/down the fields of a DateSpinner
using the mouse wheel. The current approach of having to click in a
field, then move the mouse to the arrow, then click the arrow takes more
effort than is required.
Asad.
arazvi
Postby JIDE Support » Thu Jul 27, 2006 6:26 am
It sounds like this feature should be part of JSpinner in Swing. I'll see if we can add it in JIDE code. I'll let you know.
Postby JIDE Support » Mon Aug 21, 2006 11:47 am
Just so you know, this is fixed in DateSpinner. We even added SpinnerWheelSupport class to support any JSpinner.
Re: MouseWheelListener for DateSpinner
Postby halbarad » Thu Dec 16, 2010 3:20 am
Hi
Is it possible to invert the mousewheel direction inside the DateSpinner? At the moment the number goes down when i use the wheel upwards - this is the wrong direction, the number should be increased instead.
thanks and kind regards..
-Hal-
halbarad
Postby JIDE Support » Thu Dec 16, 2010 9:51 am
It's a consistent behavior with Windows default spinners. Please try to configure the clock in Windows and get a time spinner. You will see how Windows react to the mouse wheel.
Postby halbarad » Fri Dec 17, 2010 2:26 am
Hello
I tried different Windows versions (Win7 Ultimate (german), WinXP (german), WinXP 64 (english)). Every Timespinner behaves the same - the number increases when i use the mousewheel upwards (upwards means forwards - away from me). And for me this is an absolutely logical and natural behaviour. What about the arrow Buttons in the DateSpinner? They behave like they have to - up increases the number. Also do the Arrow Keys on the Keyboard. Everything is fine except the mousewheel rotation direction.
In what version of Windows do the TimeSpinners react as you described?
kind regards..
-Hal-
halbarad
Postby JIDE Support » Fri Dec 17, 2010 10:59 am
Sorry that I didn't mention that JIDE DateSpinner behave exactly like Windows. It will increase the number while moving wheels upwards. I tried it in 2.10.2. Can you please let us know the JIDE release number, your OS, etc. if you notice a different behavior?
Postby halbarad » Thu Dec 23, 2010 1:27 am
Okay I see ;)
I work with an older version of Jide (1.9x). The current version seemingly works fine. So I really have to think about updating our components with the current jide version.
Thanks a lot and kind regards.
-Hal-
halbarad
Users browsing this forum: No registered users and 162 guests
