Searchable improvement
Postby nicola.gioia » Tue Jul 25, 2006 8:40 am
With existing API is possible to get programmatically the index on which a String will be inserted without insert them.
This should be usefull for example in a Dictionary listed in a JList on which we want to see the nearest word of a new word that should be inserted in the dictionary, but before to insert them.
nicola.gioia
Postby JIDE Support » Tue Jul 25, 2006 3:26 pm
I think it should be possible with current APIs. For example, you can use findFirst(String s) to find the insert location from a list.
Postby nicola.gioia » Fri Jul 28, 2006 2:22 am
Yes it is possible, but i must use the findNext function using all the prefix until the result of the findNext is -1 or i reached the end of the String to search.
nicola.gioia
Postby JIDE Support » Fri Jul 28, 2006 3:48 am
I re-thought about this. I don't think Searchable is a good candidate for this. The reason is Searchable doesn't assume the list is sorted. However to do what you want, it'd better to assume the list is sorted.
Postby nicola.gioia » Fri Jul 28, 2006 8:42 am
Sorry I forget to tell that the list on which I must find the future position of the string is a sorted list, elsewere the problem is inexistent.
I have a sorted searcheable JList with about 200000 sorted words and I must highlight the two word that will surround a new word before it we will be added.
I tried to use the subsequent code:
   protected int searchNearestElement(ListSearchable list,String text) {
      int ret = 0;
      int temp = 0;
      int index = 0;
      list.setCursor(0);
      while(temp >=0 && index < text.length()) {
         temp = list.findNext(text.substring(0, index+1));
         if(temp!= -1)
            ret = temp;
         index++;
      return ret;
But this don't fine in case of a list containing:
customise
customize
customized
customizing
customs
when we try to search the word
customizzation
because the algorithm find the index of customize word instead of the index of customizing
nicola.gioia
Postby JIDE Support » Fri Jul 28, 2006 2:43 pm
Anyway, I don't think it worth the effort to adapt Searchable interface for this purpose. Searchable uses brute-force searching as it assumes the list is not sorted. So it's not the most efficient way. You can easily do this using a bi-search algorithm. So just write your own code to do it.
