SortableTable.sortColumn(...) should be configurable
Postby arazvi » Wed Jul 19, 2006 8:28 am
SortableTable.sortColumn(String) and
SortableTable.sortColumn(int) only sort ascending.
I need to be able to programmatically sort descending.
Can you please add this functionality ?
Asad
arazvi
Postby JIDE Support » Wed Jul 19, 2006 4:10 pm
You can try to use the method
public void sortColumn(int column, boolean reset, boolean ascending)
on SortableTableModel.
Really ? What version ?
Postby arazvi » Thu Jul 20, 2006 5:55 am
What version of JIDE is this method in ? I did not see it in the JavaDocs for version jide.1.9.1.05.
Thank you.
Asad.
arazvi
Ignore last message
Postby arazvi » Thu Jul 20, 2006 8:28 am
Sorry...Was looking at SortableTable instead of SortableTableModel :roll:
arazvi
Re: SortableTable.sortColumn(...) should be configurable
Postby Kalyani » Wed Nov 16, 2011 4:58 am
I am trying to sort a column using the below code.
SortableTable sortableTable = new SortableTable(portfolioGrid.getModel());
sortableTable.sortColumn("Weight");
Here portfolioGrid -> JideTable
1st column in that table is "Weight".
I have added the JideTable via the JIDE Palette in GUI Builder of Netbeans.
But this is not working. I have tried everything. Could you please help ??
Kalyani
Postby JIDE Support » Wed Nov 16, 2011 11:39 am
It does work for me. Attached is the test case FYI. Please share with us a test case if you still have the issue.
SortableTableDemo.java
(15.54 KiB) Downloaded 4638 times
Postby Kalyani » Thu Nov 24, 2011 4:37 am
Ya I got it to work .. :D
Just 2 more questions -
1) Am getting a character sort . In the sense if i enter 3 numbers - 123,12 and 33. Ascending Sort returns -> 12,123 and 33. Could you please help me get a complete numeric sort.
2) How do i get the null values to appear in the bottom ( irrespective of ascending and descending ) ? . I am entering 3 values in a 15 row table. On clicking on the table header to sort, the 3 values go to the bottom of the table.
Thanks for your help :)
Kalyani
Postby Kalyani » Thu Nov 24, 2011 5:38 am
Also i am unable to add a new column dynamically to Sortable Table.
None of the wrappers above it also have this functionality.
I need to add a new column programmicatilly to the SortableTable.
Kindly help.
Kalyani
Postby JIDE Support » Thu Nov 24, 2011 7:32 am
To realize both your goals, please use ObjectComparatorManager#registerComparator() to register a customized comparator for the column. You would also need let SortableTableModel#getColumnComparatorContext() to return the corresponding comparator context you have registered.
Kalyani wrote:Ya I got it to work .. :D
Postby JIDE Support » Thu Nov 24, 2011 7:34 am
Please give JIDE CalculatedTableModelDemo a try for adding columns dynamically.
Kalyani wrote:Also i am unable to add a new column dynamically to Sortable Table.
Kindly help.
Users browsing this forum: No registered users and 83 guests
