Horizontal scrolling with Mouse Wheel
Postby Celso » Tue Jun 27, 2006 6:00 am
I want to know if is planed to add the support of the horizontal scrolling with Mouse Wheel on components like JideScrollPane.
Celso
Celso Fernandes
Celso
Postby JIDE Support » Tue Jun 27, 2006 7:49 am
I think JideScrollPane (as well as JScrollPane) supports horizontal wheel scroll. However vertical wheel scroll has a high priority. Only if there is no vertical scroll bar, it will scroll horizontally using wheel. So I guess you are looking for an option to make horizontal scroll a higher priority, aren't you?
Postby Celso » Tue Jun 27, 2006 11:07 am
I'm unsing a Microsoft mouse that allows to scroll horizontal and vertical. With this mouse I can scroll for example in Eclipse without problem. I'm looking for same behaviour.
Celso
Celso Fernandes
Celso
Postby JIDE Support » Tue Jun 27, 2006 11:12 am
I see. I wonder if Java MouseWheelEvent supports it at all. I didn't see a field in MouseWheelEvent tells if it's horizonal or vertical. It's no surprise that Eclipse works because it usually gets the native behavior.
Postby Celso » Tue Jun 27, 2006 11:11 pm
Currently Java MouseWheelEvent does not supports the horizonal scrolling.
Celso Fernandes
Celso
Postby JIDE Support » Wed Jun 28, 2006 7:51 am
Here is the bug report for it.
http://bugs.sun.com/bugdatabase/view_bu ... id=6440198
I guess we will have to wait for Sun to fix it.
Users browsing this forum: No registered users and 132 guests
