Multiple Close button states in JideTabbedPane
Postby RemingtonSteel » Thu Aug 05, 2004 11:23 am
It would be nice to have the option to set tabs in JideTabbedPane with either the close button on or off for specific tabs. The best would be to hide the close button for "non-closable" tabs, and to show the button on closable tabs. Or, if that's not possible, to disable the close button on tabs that are not "closable".
For example, the developer could call:
addTab(String title, Icon icon, Component component, String tip, boolean showCloseButton);
-or-
enableCloseButton(String TabTitle, boolean enableCloseButton );
This would be a great addition to a great component.
RemingtonSteel
Postby JIDE Support » Thu Aug 05, 2004 11:35 am
Thanks for the suggestion. We will consider doing it in the near feature.
Postby JIDE Support » Tue Jun 14, 2005 3:44 pm
I forgot to post an update on this thread. In fact, this feature has been added since 1.7.0.04. You can see change log at http://www.jidesoft.com/history/release.htm#1.7.0.04.
Users browsing this forum: No registered users and 83 guests
