SortableTableModel with custom comparator
Postby orome » Thu Apr 13, 2006 2:56 am
Is there the possibilty to add a feauture like setCompareIgnoreCase(bool); on the SortableTableModel. Or a more generic thing like setComparator(column, Comparator);
I use the SortableTableModel mainly with strings, so for me the first case would be easier to use...
Thanks Orome
orome
Postby JIDE Support » Thu Apr 13, 2006 10:04 pm
Those methods will indeed make it convenient. However they might be problematic too when table model changes. I propose a getComparator method on SortableTableModel. If getComparator(columnIndex) return a non-null value, we will use it. Otherwise, we will use getColumnClass to look up in ObjectComparatorManager.
Postby JIDE Support » Mon Apr 24, 2006 10:23 am
Just so you know, this feature is added to 1.9.1.02.
(Grids) Added getComparator(int column) method in SortableTableModel. You can override it to return any comparator you wanted.
Postby orome » Mon May 08, 2006 1:51 am
Very well! You guys are so fuckin fast! (sorry for the words ;-)
i'll give it a try just now.
orome
Users browsing this forum: No registered users and 133 guests
