Automatic collapse of row in HierarchicalTable
Postby nicola.gioia » Mon Apr 03, 2006 6:53 am
If i have a HierarchicalTable with a HierarchicalTableModel and a row that is expanded will receive an event, recognized at TableModel level, that update the table model and make the hasChild(Object) to return false. after this event the icon to expand/collapse the row disappear, but the row is not collapsed.
An example of code to reproduce the bug is:
(before we must expand the row and after uncheck the checkBox)
import java.awt.event.*;
import javax.swing.table.*;
import com.jidesoft.grid.*;
public class HierarchicalTest {
   static String[]colNames = {"col1","col2"};
   static String[][]tabledata = {{"elem11","elem12"}};
   static String[][]tableData1 = {{"subTable11","subTable12"}};
   MyTableModel model;
   HierarchicalTable mainTable;
   public HierarchicalTest() {
      model = new MyTableModel(tabledata,colNames);
      mainTable = new HierarchicalTable(model);
      mainTable.setComponentFactory(new HierCompFactory());
      JPanel contP = new JPanel(new BorderLayout());
      contP.add(new JScrollPane(mainTable),BorderLayout.CENTER);
      JCheckBox cb = new JCheckBox("isHierarchical");
      cb.setSelected(true);
      cb.addActionListener(new ActionListener() {
            model.haschild = ((JCheckBox)e.getSource()).isSelected();
            model.fireTableDataChanged();
      contP.add(cb,BorderLayout.SOUTH);
      JFrame d = new JFrame();
      d.setContentPane(contP);
      d.pack();
      d.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
      d.setVisible(true);
   class MyTableModel extends DefaultTableModel implements HierarchicalTableModel{
      boolean haschild = true;
      MyTableModel childModel;
      public MyTableModel(Object[][] data, Object[] columnNames) {
         super(data, columnNames);
      public boolean hasChild(int arg0) {
         return haschild;
      public boolean isHierarchical(int arg0) {
         return true;
      public Object getChildValueAt(int arg0) {
         if(childModel == null) {
            childModel = new MyTableModel(tableData1,colNames);
            childModel.haschild = false;
         return childModel;
      public boolean isExpandable(int arg0) {
         return true;
   class HierCompFactory implements HierarchicalTableComponentFactory{
      public Component createChildComponent(HierarchicalTable arg0, Object arg1, int arg2) {
         JPanel p = new JPanel(new BorderLayout());
         p.add(new JTable((TableModel) arg1),BorderLayout.CENTER);
         return new HierarchicalPanel(p);
      public void destroyChildComponent(HierarchicalTable arg0, Component arg1, int arg2) {}
      new HierarchicalTest();
There is a way to fix this problem and automatically collapse the expanded row?
nicola.gioia
Postby JIDE Support » Mon Apr 03, 2006 10:31 am
I'll fix it.
Postby nicola.gioia » Tue Apr 04, 2006 12:42 am
Sorry, but there is a workaround to solve temporarily the problem, before the fixing?
nicola.gioia
Postby JIDE Support » Tue Apr 04, 2006 8:38 am
Please use a development patch at http://www.jidesoft.com/downloads/jide.1.9.0.02.zip while waiting for formal release. We will have it released this week.
Postby JIDE Support » Mon Apr 10, 2006 12:03 pm
Just so you know, the fix is included in 1.9.1 formal release.
Postby nicola.gioia » Thu Jun 01, 2006 3:43 am
I found another little problem.
I have a table with only first row expandable, and when the first row is expanded, and someone add a row on the top of the table, the row expanded will remain expanded and positioned on the bottom of the old first row and is not possible to collapse it.
The step to reproduce the bug are:
    1 - expand the row expandable
    2 - click on button addRow.
The code needed is:
   MyTableModel model;
      JButton b = new JButton("addRow");
            model.insertRow(0,new String[]{"elem01","elem02"});
      contP.add(b,BorderLayout.NORTH);
      d.pack();
      d.setVisible(true);
      private static final long serialVersionUID = 1L;
         return arg0 == 0;
         return true;
         return childModel;
         return true;
         return new HierarchicalPanel(new JLabel("SUBTABLE!!!"));
    [list=][/list][list=][/list][list=][/list]
    nicola.gioia
    Postby JIDE Support » Thu Jun 01, 2006 8:51 am
    This is not really a bug. You have code
                return arg0 == 0;
    Basically you specified only the first row has child. That's why the +/- button is not displayed after you added a row.
    Postby nicola.gioia » Fri Jul 21, 2006 2:48 am
    I have a problem that I cannot reproduce in few row code.
    When in the hierarchical table with at least a row expanded I insert a row on top of the table the elements of the table will be update correctly, and also the selected row is correctly shifted by one but the component of the subtable is shifted by two position.
    Have you a suggestion of how find which is the listener that move downward the child element twice instead of one?
    nicola.gioia
