Pivot Grid persist field filter with "yes" instead "not"
Postby immobilia » Mon Apr 17, 2023 7:49 am
Hi, I use PivotTablePersistenceUtils to store my table and options like filters on data columns.
But i want store data column values filter by inclusion instead exclusion.
The user want only checked values.
He doesn't want new values, if new values appears.
In my exemple "1 828", "18 775", "14 895" are unselected.
That's the com.jidesoft.pivot.PivotTablePersistenceUtils store in .xml :
filter=";		not		com.jidesoft.grid.MultipleValuesFilter		(Vide)	1 828	18 775	14 895"
But, instead, i want store only the selected values (20 720, 20 763, 20 801, ...)
Is a way for this ? (Revert the "not" filter by a "only/equal").
JIDE_Pivot_Grid_Developer_Guide
JIDE_Grids_Developer_Guide
pivot.xml
(19.23 KiB) Downloaded 10003 times
immobilia
Users browsing this forum: No registered users and 97 guests
