Java 17 and FlatLaf support
Postby rogerbj » Tue Feb 28, 2023 3:33 am
I've scanned some other posts related to Java 17 and FlatLaf support and the problems identified by "JIDE support" going that path.
What about scrapping all current L&Fs support in JIDE and open a new Java 17/FlatLaf only branch? FlatLaf is the de-facto L&F toolkit for Swing apps today, it is being developed, supported and works really really well. JIDE software would have a great opportunity going forward and even attract new customers.
My company have sponsored the FlatLaf project in order to get adjustments for some JIDE OSS components to work/look better with FlatLaf. Having full or at least more support for JIDE in FlatLaf would be fantastic.
Looking at the JIDE codebase (src) there are a lot of really old L&Fs available and I doubt anyone are using them other than just cluttering the APIs and restricting future updates in JIDE such as Java 17 and other.
What do you think?
rogerbj
Re: Java 17 and FlatLaf support
Postby JIDE Support » Tue Feb 28, 2023 9:14 am
You are right. I looked at the code recently and realized that in order to support Java 17 without using add-export, a lot of L&F have to be redone, not sure if it is even possible to support the native Windows L&F. That means it has to be a new branch that is not backward compatible
Postby rogerbj » Tue Mar 21, 2023 1:11 pm
And what is your plan?
rogerbj
Postby kobi_sadoun » Tue Jun 13, 2023 8:10 am
Joining the question of rogerbj.
@JIDE Support what is your plan?
kobi_sadoun
Users browsing this forum: No registered users and 9 guests
