Avoid reflection in ResizableSupport impls for Java 17
Postby tristanzhou » Thu Jun 30, 2022 2:50 pm
We had patched a workaround for fixing the reflection issue in the docking framework after upgrading to Java 17. I think it may be doable to add it to the source code from your side as well. Please find it in the attachement.
Btw, I have seen that you mentioned in another post about branching code for Java 17. Will JIDE support Java 17 in a future release? Any plan for that? Thanks.
Cheers,
Tristan
fc-resizable-refactor-java17.zip
(3.33 KiB) Downloaded 12092 times
tristanzhou
Users browsing this forum: No registered users and 122 guests
