Automatic licence lookup
Postby charliewakeup » Thu Sep 02, 2021 7:25 pm
It would be nice if, instead of having to call Lm.verifyLicense, we could instead put a file somewhere on the classpath like /META-INF/licences/jide.properties which JIDE would look up itself when it wants to find a licence.
Reasoning is, it's easy to forget to call Lm.verifyLicense (or rather the utility method we made call it) from every place which could possibly be using JIDE, and generally bugs of this sort crop up at random due to the order tests run in, which makes discovering the bug surprising every time.
The suggestion to "call it in the main method" never really appealed to us, because:
  • there are multiple main methods so you can still forget to call it and the scope of the main method doesn't know whether JIDE will be used or not, which makes it the wrong place to make the decision
  • unit tests don't have a main method anyway so those would still have to do something else
  • it's no longer simple to "just use" a component, e.g. in a GUI builder, because you have to know about JIDE licensing
charliewakeup
Re: Automatic licence lookup
Postby JIDE Support » Thu Sep 02, 2021 10:44 pm
You can already do that. The properties file is
com\jidesoft\utils\utils.properties
The content of the file should be
verifyLicense.companyName=xxxx
verifyLicense.projectName=xxxx
verifyLicense.licenseKey=xxxx
You can also pass in them as system properties.
Postby charliewakeup » Tue Sep 14, 2021 7:31 pm
Aha! Well there is something I didn't know. We will switch to doing it that way.
charliewakeup
Users browsing this forum: No registered users and 102 guests
