Sortable table column header sorts only one page
Postby s.durmus » Tue Nov 14, 2017 12:18 am
Hi there,
In my project I am using Sortable table . The table has a page structure each page contains 10 rows.
I need to sort all rows in the table not in the page. Is it possible to do this by clicking header column only?
thanks.
s.durmus
Re: Sortable table column header sorts only one page
Postby JIDE Support » Tue Nov 14, 2017 8:52 am
If you use JIDE Data Grid to do the paging, it will support sorting the whole table even user can only see 10 rows in the page.
Postby s.durmus » Wed Nov 15, 2017 7:00 am
Ok. This problem is solved. But I use filterable table model and custom filtre language is not support. 'custom' text must be 'Özel' in my language . Like this.(custom-filter.png)
second problem; custom filtre windows language text is wrong. Like this.(custom-filter-window.png)
I thing, I can override getResources method. But I dont know, how to use.
I'm very happy if you explain your solution.
s.durmus
Postby s.durmus » Wed Nov 15, 2017 7:07 am
table is HierarchicalTable
table model is FilterableTableModel
s.durmus
Postby JIDE Support » Wed Nov 15, 2017 7:46 am
There are corresponding translations in the jide-properties.jar. You can unjar it and find the correct entry and translate them yourself. All those strings were contributed by our users so if you update it, please send us your translation. Thank you!
Users browsing this forum: No registered users and 98 guests
